HI
I recently upgraded my Samsung NOTE 4 to android 6.01.
Prior to the upgrade syncing was flawless.
Presently, the only way to sync is to remove the device and re add it.
It will sync only once and then I have to do the whole exercise of removing the device and adding it again.
strange it works only once.
Gone thru the numerous suggestion on the forum.
I have tried reseting the device numerous times.
I've removed the bluetooth paring and re installed it from scratch.
Believe I am running the most recent Fitbit app.
Not sure what else to try... I am positive it has to do with the updated operating system.
will there be an another update soon?
Any other suggestions?
Best AnswerFinally fixed the syncing problem on the NOTE 4.
Steps taken
1) Removed the device.
2) Ensured pairing did not exist any more on phone.
3) Removed FitBit App
4) shut down Phone
5) shutdown Surge
6) Re installed App from scratch
Its been almost 24 hours and it is syncing as previously
Hope the above can help someone else
Hey there @GalleryStyle, we really appreciate your patience with this! Many thanks for sharing the steps you succesfully took to solve this syncing issue.
I noticed that you are new in the Community, welcome! I encourage you to join us at Discussions board, there you can share your story, find some fitness tips, recipes and more! Give it a look!
Happy stepping! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
Best Answerit works perfectly for me thank you 🙂
That's great @MartinTraedholm I'm glad to hear that! I noticed that you are new in the Community, welcome! I encourage you to join us at Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more! Give it a look!
