09-17-2017
07:34
08:08
RobertoME
09-17-2017
07:34
08:08
RobertoME
Hi all lights flashing and cannot sync. Any ideas ? Thanks
Moderator Edit: Updated Subject For Clarity.
09-18-2017 09:59
09-18-2017 09:59
09-18-2017 08:07
09-18-2017 08:07
Hello @Mukewithwrs04, let me start by giving you a warm welcome to the Fitbit Community! I was reading you are having a hard time to sync your tracker. When you say all lights are flashing I assume you are using a Flex 2. My recommendations is to giving it a try to these troubleshooting steps: Having trouble syncing? (here's how to fix this).
See you until the next one and I hope this helps.
09-18-2017 09:59
09-18-2017 09:59
10-05-2017 10:25
10-05-2017 10:25
Hello @Mukewithwrs04, thank you for keep me posted. I saw your reply is marked as an "Accepted Solution" but by the context of your response I'm not sure if you re still experiencing the syncing issues you mentioned before. Can you confirm this for me please?
See you later and for more questions I'll be around.
06-12-2021 22:53
06-12-2021 22:53
Put your Flex 2 in the charging cradle. Make sure the cradle is connected to power and the pins line up. Underneath the cradle is a square button. Press it 3 times within 5 seconds. This will power cycle the flex unit and restart it. You'll find it will sync properly now. You may need to do it twice, but it has never failed to work for me.
