The option to change unit of measure when logging food in the app has disappeared. I can enter "100" but cannot specify whether this is grammes, ml, servings, etc
I have contacted the Fitbit support on Twitter but they were unhelpful. I have tried:
- Uninstalling the Fitbit app
- Updating my Fitbit
- Updating my phone
I can log food properly through the Web dashboard, but just not on the app.
I have a fix!
Tap the white space between the serving size input number and the calories. The dropdown menu will appear where you would expect it.
Basically, it's there, but they've just decided to make it invisible
Best AnswerNot necessarily a fix, more of a work-around. Logging calories is hardly a new concept and should not be this glitchy.
