10-05-2023
06:47
10:57
RodrigoMFitbit
10-05-2023
06:47
10:57
RodrigoMFitbit
Has anyone else had the issue of their fitbit Battery dying within a few hours after being fully charged after this new last update?
10-05-2023 10:58
10-05-2023 10:58
@Yrcountrygrl. Welcome to the forums. Thanks for reaching about the battery of your Fitbit device. Which device do you own?
I suggest you take a look at the following article on our help site: Can I extend my Fitbit device's battery life?. Here you find tips for different scenarios. Make sure to try them all.
Best Answer10-05-2023 12:59
10-05-2023 12:59
10-09-2023 22:14
10-09-2023 22:14
I'm experiencing the same issue and never had this issue until the new software update. My Fitbit device is essentially unusable at this point. Please fix asap!
10-10-2023 03:56
10-10-2023 03:56
10-15-2023 10:43
10-15-2023 10:43
None of them work
Best Answer10-15-2023 12:41
10-15-2023 12:41
I have a Versa 2, it's gone from doing 3 - 4 days on a full charge to 2 - 3 days with the new app.
I've removed the new version an rolled back to 3.88 and I can already see the battery drain on the device is less.
