11-08-2023 17:19 - edited 11-09-2023 04:14
Resolved, so never mind.
It showed up under Sleep Duration tab on the next day. Apparently, if you buy premium, it won't show up until you've completed your first sleep *after* subscribing. Then it doesn't apply to prior nights, which is what I expected it to do.
Fitbit would be wise to at least put a "placeholder" up with the disclaimer that data will not be visible until 24 hours after subscribing to premium.
FWIW -- not really seeing much value in premium. Certainly not worth the monthly fee. Maybe things will look better after seeing the monthly profile.
11-09-2023 04:20
11-09-2023 04:20
See my edit to the OP. Did a long chat with support and they couldn't figure it out, just escalated and promised an email. Solution became obvious by way of patience. 😉
11-09-2023 04:07
11-09-2023 04:07
Hello @dglexie and welcome to the Community. I moved your post to the Android app forum, a better fit for your question. Premium members get a screen like this when they tap on a sleep record:
This has the Restoration tile that shows your sleeping heart rate, restlessness and EOV graph. If you don't see this, I only have general troubleshooting advice like logging out and logging back in. A fellow Android user might have more help.
BTW, all Premium features are only on the mobile app and aren't available on the web dashboard.
Laurie | Maryland
11-09-2023 04:20
11-09-2023 04:20
11-09-2023 04:28
11-09-2023 04:28
Premium is a subscription service. I'm talking about that subscription service.
Best Answer11-09-2023 05:25
11-09-2023 05:25
@dglexie I'm happy that you got this all sorted out. Your original post suggested that you had Premium for several days. No harm, no foul. This Fitbit Premium page has a good overview of Premium features. IMO, Premium is pricey if all you want are the sleep details. Only you can decide if this feature is best for you. Good luck.
Laurie | Maryland
