@mandyp67 Hi and Welcome - the average should be 4-6 days for a charge if it is a lot less have you checked that you have not left an exercise running? have messages and texts being displayed on your device etc
see the following link that may give you a few ideas also have you noticed any changes to the way the green light are displayed? are they brighter than normal, stay on constant instead of a rapid flicker (if this is the case the restart option may be the better option to start with)
you could also try disabling Bluetooth , restart phone and re-enable Bluetooth
failing that you may need to restart your device - you may need to do this 2-3 times in a row
and lastly if that doesn't solve the issue you could give customer support a call the phone number will appear once the office is open (usually 0800 - 1900 Mon-Fri and 1000 - 1700 weekends in the UK)
This is for the UK but should you need to change country scroll to the bottom and look for United Kingdom with a down arrow next to it and click on the arrow now you can select your relevant country and the page will refresh
Kind Regards
Wayne
