04-27-2017 05:49
04-27-2017 05:49
Samsuns s7edge and alta rh.. when i get a text it only reads new message.. i notifications on and read sender and message.. i also turned on fitbit in the phones notifications setting
Best Answer04-30-2017 12:30
04-30-2017 12:30
Thanks for stepping into the Community @Kongsize!
In this case I'd recommend that you check the instructions provided by @ErickFitbit. They should get your text notifications to work properly.
If that doesn't work, or you have already tried it, please let me know.
Best Answer05-03-2017 12:54
05-03-2017 12:54
My Alta does not show calls or texts. I just got it today.
Best Answer05-08-2017 13:30
05-08-2017 13:30
Thanks for stepping into the Forums @Twade!
I'd like to take a closer look into this situation. Are you also using a Galaxy S7 Edge? If not, please let me know what mobile device you are using so that I can check on what is going on.
Look forward to your reply so that I can help you make sense of this situation.
Best Answer05-08-2017 14:16
05-08-2017 14:16
Best Answer05-09-2017 14:18
05-09-2017 14:18
Hello @Twade!
Those are some great news. I'm happy to hear that you managed to get the notifications to work correctly.
If you do not mind me asking, what was the steps that you missed? Knowing that could help other users on the Forums.
Let me know if you have any questions.
