07-02-2018 12:11 - last edited on 09-04-2019 08:45 by MatthewFitbit
So having difficulties connecting my new Aria 2 to Wifi.
It sees the network, accepts the password, tick apears then sync process then says can't connect
I have tried the following:-
What is my next step? Is this a firmware issue or an issue with the synchronisation servers?
Yours hopefully
P.s also tried taking batteries out for ten min, router is 8 feet in direct line of sight to router, there are other wireless devices on network which are working fine.
Geoff
11-29-2018 05:48
11-29-2018 05:48
@KarynaH Welcome to our Fitbit Community! I'm sorry to hear that your Aria 2 is not connecting to your network either. I would like to follow up on this issue and would like you to try the following troubleshooting steps: Restart your router and after this, set up your scale from scratch.
On an aside note, I would like to know if you made changes to your network (WiFi password, router or router settings).
@JSSC I'm sorry about the experience you had with your Aria 2. I appreciate your feedback and comments since this helps us to keep improving.
07-03-2018 04:29
07-03-2018 04:29
@GeoffBiscuitGod I noticed that you joined our Fitbit Community recently. Welcome aboard! It seems that you have tried pretty much all the recommended troubleshooting steps for the connection issues that your new Aria 2 is experiencing. Thank you for trying all this before getting in touch with the forums.
Due to this, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution for you. You should receive an email from them soon.
Let me know if you have any doubts!
07-03-2018 14:31
07-03-2018 14:31
I know that @JuanJoFitbit mentioned forwarding your case to Support, but in the meantime, have you reset the scale? Just remove and re-insert the batteries after 10 seconds.
one cruise ship at a time!07-03-2018 15:47
07-03-2018 15:47
Thanks @DramaQueenDiva I have done that to no avail. I have also recieved communication from technical support which i have included below in case it helps others:-
07-05-2018 06:56
07-05-2018 06:56
@GeoffBiscuitGod Thank you for taking the time to troubleshoot this issue! I would like to follow up and would like to know if our Support team provided a solution after you replied to them.
Looking forward to your response!
08-08-2018 18:57
08-08-2018 18:57
Did you ever get your Aria 2 working? I just bought one and am having the same problem you are 😞
08-09-2018 04:23
08-09-2018 04:23
@SandiJo Thank you for joining us in this thread and our Fitbit Community! Let me go ahead and help you with the setup issues that your Aria 2 is experiencing. Please let me know if your scale is displaying any error message. Also, let me know if you are following the setup process as advised in this article and your router settings comply with the required settings that are also listed in the article.
Let me know how it goes!
08-09-2018 12:11
08-09-2018 12:11
I have spent many hours calling fitbit and my internet provider. I have tried everything you have. I have been basically told to give up. You won't get it working.
08-09-2018 12:50 - last edited on 08-11-2018 08:28 by JuanJoFitbit
I found this to be the case too. Fit it offered to warranty exchange it but I had massive doubts that a new device would work so I just took it back to the shop I bought it from and told them it wasn't fit for purpose. Awful product and scripted responses when trying to resolve.
They did try saying that my phone model wasn't supported but backed down when I got the the same results on a Bluetooth enabled laptop. It was at that point they offered me a warranty replacement.
Moderator edit: format
08-10-2018 07:48
08-10-2018 07:48
After many hours of frustration and teeth-gnashing, we finally got it working. It has lost wifi signal a couple times but seems to be ok now? <crossing fingers>
08-10-2018 08:08
08-10-2018 08:08
I just got my Aria 2 yesterday Aug. 09,2018. When I first tried to set in up on my phone on my Fitbit app it only showed the Aria not the Aria 2 so nothing happened when I tried to add it. I walked away and came back about 15 min later and then the Aria 2 was on the app when I selected add new device. Once it recognized the device the rest was easy. It asked my for my wi-fi password and it was successful. I got my little check-mark. The only thing is when I weighed myself I got an error message. I didn't realized when the little feet on the scale backed off it was telling me to get off of the scale too. I guess that might me in the directions somewhere but not on the quickstart guide unless I missed it. I weigh the same as I do on my old scale which I know is accurate so I'm pleased so far.
08-11-2018 08:28
08-11-2018 08:28
@JSSC I totally understand how you feel about this and I appreciate your feedback. This will be forwarded to our team since this helps us to keep improving.
@GeoffBiscuitGod I'm sorry to hear that your Aria scale was unable to work properly. However, I'm glad to hear that our Support team offered a replacement unit. Your feedback is greatly appreciated.
@SandiJo @msdoe I'm also sorry to hear about the setup difficulties you experienced with your Aria scales and I'm glad to hear that you guys were able to connect them to your WiFi networks. Thank you for posting the update here.
I'll be around if you guys have any questions!
11-28-2018 12:34
11-28-2018 12:34
Hi JuanJo, my Fitbit is experiencing the same problem. 😕 I had my husband try all the same things as Geoff but we are still seeing the little face with an X and NO WIFI scrolling on the screen. Will you be able to assist?
11-28-2018 13:58
11-28-2018 13:58
11-28-2018 14:31
11-28-2018 14:31
11-29-2018 05:48
11-29-2018 05:48
11-29-2018 05:52
11-29-2018 05:52
12-03-2018 11:05
12-03-2018 11:05
12-05-2018 14:55
12-05-2018 14:55
So, the saga continues, Aria 2 less than 1 week old (replaces original Aria, never a problem).
Setup last Sunday no problems, synced, all good until Monday.
Tuesday - did not sync, did not realize until night.
This morning no sync - wifi connection error, tried the obvious for an hour, refuses to reconnect to wifi.
Have not done a hard reset yet - nothing changed on my network, high end router with no funny setups.
Could the wifi gizmo inside the scale just gone bad??
Very disappointed after reading of all the other individuals with similar problems.
12-05-2018 16:31
12-05-2018 16:31
