01-07-2018 20:57 - last edited on 09-04-2019 08:45 by MatthewFitbit
Just purchased Aria2 to go along with my new tracker. Trying to setup the device using the iOS app (updated to the latest version). Aria2 won't accept the password for the wifi. A google search shows this is a pervasive problem. This is embarrassing. First, why does the scale even require a wifi setup? if it can connect to a smartphone (and hence the app) via bluetooth that should be all that's required. Second, when will fitbit officially acknowledge the problem, offer a fix or recall the product altogether? I'll probably return the scale (and maybe even the tracker), which is a shame and a waste of my time.
01-08-2018 06:30
01-08-2018 06:30
@wazee Thanks for participating in our Fitbit Community! Seems odd that your Aria scale is not accepting your WiFi password. I would like to follow up and would like to know if the issue persists or if your Aria 2 could be set up.
Regarding your inquiries, the Aria 2 sends your data via WiFi to your Fitbit Dashboard in order to update your record of weights. Also, the setup process has been improved so i can be via Bluetooth. I'd like to share the setup instructions that are listed in this help article.
Looking forward to your response my friend!
01-21-2018 19:11
01-21-2018 19:11
Does the Aria 2 accept passwords with special characters? I have an Aria and just added a new router to our house. I just learned after over an hour of trying to get the dang thing to connect that the Aria does not accept passwords with special characters. I am not going to change my password for this one device so before purchasing an Aria 2 I want to be sure it will connect. It doesn't appear to be an issue with this version, but I am hoping someone can confirm before I purchase the Aria 2.
Thanks in advance!
01-23-2018 04:00
01-23-2018 04:00
@kalia Thanks for joining us in this thread! Thanks a lot for your interest in the new Aria 2. Regarding your question, the Aria 2 does accept and connect with passwords that contain special characters. Also, the setup is easier since it's done via any smartphone's Bluetooth.
Don't hesitate to get back if any other question arises my friend!
01-23-2018 08:52
01-23-2018 08:52
@wazee wrote:Just purchased Aria2 to go along with my new tracker. Trying to setup the device using the iOS app (updated to the latest version). Aria2 won't accept the password for the wifi. A google search shows this is a pervasive problem. This is embarrassing. First, why does the scale even require a wifi setup? if it can connect to a smartphone (and hence the app) via bluetooth that should be all that's required. Second, when will fitbit officially acknowledge the problem, offer a fix or recall the product altogether? I'll probably return the scale (and maybe even the tracker), which is a shame and a waste of my time.
Ok, just clearing up one thing: the tracker and the scale have nothing to do with each other, so if you wish to return the scale, there is no need to return the tracker as well as it (the tracker) is working perfectly fine.
Second, you may want to consider restarting the scale by removing the batteries from the back of it for about 30 seconds. My Google Home Mini experienced a similar problem yesterday, but once I rebooted it (by unplugging it from the wall), it works fine. It's a different device, I know, but still may be worth a shot.
one cruise ship at a time!01-25-2018 07:07
01-25-2018 07:07
Thanks for the pointers. I definitely tried your suggestion many times to no avail.
The tracker and the scale are related in a sense. They are part of the Fitbit experience. That is, in my dashboard i get to see data collected from both devices in a simple and streamlined interface. Are they absolutely necessary for each other? No. But neither is an iphone and a mac (vs a PC for example), but having them both simplifies some task. If i returned the scale for one from a competitor, I'd probably be interested in the competitors tracker instead.
Anyway, the good news is i don't need to return either device. I tried everything under the sun to get the scale to work with no luck. Finally i remembered i have an Airport extreme which can be used as a router. I hooked it up to my current verizon router and connected the scale to its new wifi network instead. Worked the first time.
02-07-2018 09:00
02-07-2018 09:00
I have been sussefulkt using my Aria2 for 8-weeks. Up until today it has been great. Today it gave me an error that the Wifi password is suddenly incorrect. There have been no changes and all other devices are working fine. I tried “pairing” again and always get “wrong password”. Help?
02-07-2018 10:10
02-07-2018 10:10
@Wanderer23 - have you tried entering your wifi password again and are you able to get it connected? If so, has it happened again?
Actively managing your weight? Find accountability buddies on the Manage Weight board
02-07-2018 11:56
02-07-2018 11:56
02-07-2018 12:19
02-07-2018 12:19
@Wanderer23 Thanks for getting back to me. Is the password less than 32 characters? Is it at all possible to change the password and try logging in again?
02-07-2018 14:29
02-07-2018 14:29
02-07-2018 17:18
02-07-2018 17:18
@Wanderer23 I can understand changing your password wouldn't be convenient. I'm not sure what is happening. Is it at all possible to try and set up on a different device?
02-08-2018 11:53
02-08-2018 11:53
02-08-2018 13:15 - edited 02-09-2018 10:20
@Wanderer23 meaning a different device, iPad vs a phone. I'm reporting this issue to our team to see if they have any further insight.
Update: I've created a case for you so our team can review further. Someone will be reaching out shortly.
02-11-2018 02:53
02-11-2018 02:53
Hi Kate, all,
apologies to jump in on the strings,
Having the same issue with Password on my aria 2, has a generic solution been found ?
have tried all mentioned suggestions with no luck.
will it work with
Protocol: 802.11n
Security type: WPA2-Personal
Network band: 2.4 GHz
Peter
02-14-2018 10:18
02-14-2018 10:18
@Peterkotze - I'm sorry to hear this. I see you started a case with our support team. Are you still seeing an error message that your password is incorrect?
02-14-2018 10:35
02-14-2018 10:35
02-14-2018 11:17
02-14-2018 11:17
@Peterkotze thanks, someone from our team will follow up shortly.
02-19-2018 19:11
02-19-2018 19:11
So what is the deal with the WiFi Password Issue. Either acknowledge it is a bug and you are working on a fix or my entire family will gladly take back ALL the Fitbit items we have just purchased. This is ridiculous to act like you are clueless on an issue that has been reported by over 100+ individuals. I am also going to place this message on FB and Twitter to warn people not to even bother with purchasing this brand! What is the current status on an update to fix the WiFi Password Issue?
02-20-2018 17:29
02-20-2018 17:29
I’m having a similar problem. The scale is not finding my wi-fi, it does however pic up other wi-fi’s in the area. I even set up my phone to be a hotspot ... the scale picked it up once, but then would not accept the password. It’s very frustrating.
