le 01-20-2014 19:53 - dernière modification le 11-21-2017 23:58 par SunsetRunner
After just purchasing the Fitbit Aria scale in color black, opened and followed the setup procedures and now with much frustration the little round display window is showing ERR after sensing and thinking. I have gone through the setup now about a dozen times with the same result. My house temp is around 74 degree’s with low humidity.
le 01-20-2014 21:12
le 01-20-2014 21:12
Well, I am a little bit suprised to see an english comment in this forum.
If you're a native English (or American), you should probably try to go on the English version of this forum.
By the way, since I don't have an Aria, I cannot help you. Hope you'll find a solution !
Best.
