01-16-2017
01:06
14:53
01-16-2017
01:06
14:53
Please help team!
I set up my Aria and got on it this morning however it only showed me my weight and none of the other measurments that its meant to. I was bare foot and the Aria was on a hard flat surface.
I have taken the battery out and put it back in but it just keeps showing my weight and nil else.
Please advise.......bit upset. thank you
08-10-2018 01:24
08-10-2018 01:24
Best Answer09-11-2018 13:25
09-11-2018 13:25
Unfortunately my Aria stopped measuring Body fat a few years ago...now it's out of warranty. I think that the surface of the scale has some conductivity problems. As you clean it using some detergents it probably wears out..sometimes when my feet are a bit wet then it's able to do the measurement.
Best Answer11-04-2018 03:43
11-04-2018 03:43
Same problem. Body fat is just shown with a dash. Weighing five times and taking out battery does nothing (except to note that the WEIGHT is DIFFERENT each of the five times!!!)
THis may be the worst scale ever made
11-04-2018 19:25
11-04-2018 19:25
11-08-2018 05:21
11-08-2018 05:21
@Alang2473 @cah1966 @Adi86 I'm sorry about the experience you've experienced with your Aria scales and I'm sorry that they're no longer under warranty. I know how you feel about this and I appreciate your feedback and comments since this helps us to keep improving.
@dbora32 @Jbcmia I would like to follow up on the issue that your scales are experiencing with the body fat percentage. Please make sure that your scales are placed on an even or flat surface and you are stepping on them barefoot. If these details are already covered, let me know and I'll be happy to proceed accordingly.
Keep me posted! ![]()
Best Answer12-23-2018 14:57
12-23-2018 14:57
Mine started doing the same recently.
I reset the WiFi and reconnected.
It measures weight, and syncs it to my account just fine, but not measuring fat %.
I checked that my height is still in and it is.
I'm using the exact same place in the house as I have for over a year, always measuring barefoot.
Any idea how to solve it?
Best Answer12-24-2018 08:51
12-24-2018 08:51
@SunsetRunner Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your Aria is not providing body fat percentage. If you haven't done this, please re-calibrate your Aria by taking out the batteries for 15 seconds and put them back in. Once this has been done, weigh yourself 5 times in a row and see if your body fat percentage is displayed on your scale.
Let me know how it goes! ![]()
07:55
03:34
JuanJoFitbit
12-25-2018
07:55
03:34
JuanJoFitbit
Sorry did not work
Moderator edit: removed personal info
12-26-2018 03:37
12-26-2018 03:37
@Jbcmia Thank you for getting back and trying the troubleshooting steps listed above. Since the issue persists, I'll send your case to our Customer Service department and they'll be happy to follow up.
You will receive an email from them soon.
Let me know if any question arises! ![]()
Best Answer03-21-2019 20:12
03-21-2019 20:12
I’m having the same issue as everyone else. Please submit a ticket for me too.
Best Answer03-30-2019 12:10
03-30-2019 12:10
@Dougythemagicma Welcome aboard to our Fitbit Community! I'm sorry for the late response. However, I would like to follow up and would like you to follow the troubleshooting steps that I shared in this post.
As a side note, please make sure that your scale is placed on a hard surface and you are stepping on it barefoot.
If these details are already covered, please let me know and I'll be happy to proceed accordingly.
See you later! ![]()
Best Answer03-30-2019 12:34
03-30-2019 12:34
Best Answer03-30-2019 12:53
03-30-2019 12:53
Best Answer04-01-2019 04:35
04-01-2019 04:35
@Dougythemagicma Thank you for getting back and trying the recommended troubleshooting steps. Due to this, I'll send your case to our Customer Support team and they'll be happy to follow up and proceed accordingly. You will receive an email soon.
@cah1966 I'm sorry to hear that your Aria could not be fixed after trying the troubleshooting steps and I'm also sorry to hear that it's no longer under warranty. I know how frustrating this is for you and your feedback is greatly appreciated
I'll be around if more questions arise! ![]()
Best Answer04-07-2019 20:10
04-07-2019 20:10
I just recently started having this issue with my Aria too. Tried all of the troubleshooting steps to no avail. Please add me to your case and let us know when there is a resolution. It's an awfully expensive scale to not have a better warranty
04-08-2019 05:13
04-08-2019 05:13
@msaonika It's great to see you in our Fitbit Community! I'm sorry to hear that your Aria scale is not providing body fat readings either. Thank you for trying the recommended troubleshooting steps before contacting our Community.
I'd just like you to try one more workaround that has been helpful: try setting up your Aria scale from scratch. After this, weigh yourself 5 times in a row and make sure that your scale is placed on a hard surface and you are stepping on it barefoot. Let me know how it goes.
See you later! 😀
Best Answer05-24-2019 22:02
05-24-2019 22:02
My Aria scale is also not showing BF. I have reset to factory settings and tried weighing myself 5 times. It's sitting on a hard, even surface and I'm barefoot. Is there any other suggestions I can try? Thanks in advance.
05-25-2019 05:11
05-25-2019 05:11
Best Answer05-25-2019 10:04
05-25-2019 10:04
Frustrating that Fitbit can’t figure this out. Stepping on and off 5+ times is the only thing that has had some success for me. Get all the prompts “BF?”, “:heavy_check_mark:”, “Syncing”, “Thinking” but no rhyme or reason to why occasionally it spits out a BF reading. This is a software glitch that Fitbit should have fixed long ago. Losing customers to Apple every day!
05-25-2019 11:02
05-25-2019 11:02
Wow, this is so sad. I've supported Fitbit since 2010. I hope they figure something out. I really want them do better.
