12-13-2023 11:06
12-13-2023 11:06
My Aria Air has just stopped reading my weight. I have changed batteries to no avail. When I get on it just reads stay blank except some dashes on the top of the screen then goes off. Strangely, it will sync to my iPhone 12, but will read like a kilo even though I don’t see anything happening
Best Answer12-14-2023 00:11
12-14-2023 00:11
Good morning Tracey how long have you had the scale? Is there any physical damage? If no damage Do you have warranty return scale if possible with receipt copy
Best Answer12-14-2023 04:40
12-14-2023 04:40
Hello @Tracey33nz and welcome to the Community. Here is a link to the Aria Air manual. Those dashes across the top are an error message -- that you exceed the maximum weight (p 13). If you don't exceed the maximum weight, then please restart your scale (p 12).
Please contact Support if this doesn't help.
Laurie | Maryland
Best Answer12-20-2023 15:50
12-20-2023 15:50
I am also having issues with my Aria Air I purchased in April. At first it was only showing 0.0 when I stepped on the scale. I went through the steps you listed above. Now it starts flashing random numbers anywhere from 10 lbs to 350 lbs… more than 200 lbs more than I weigh.
