01-16-2024 06:49
01-16-2024 06:49
so after reading about the broken, sensing legs with the cheap plastic part and no support from Fitbit on replacements. If you want to use your area scale with broken, sensing legs and not drain the battery, here’s a simple fix. When you’re not using the scale flip it over, so the legs are facing up, and the scale is facing down. That way vibrations won’t keep turning it on and the display won’t keep draining the battery. When you want to use the scale, turn it over use it And it works just fine. Then turn it back over until the next time. Solution for a stupid problem.
