03-10-2019
09:28
14:53
03-10-2019
09:28
14:53
Was all working perfectly for a while, then kept getting intermittent sync problems, works one time, not the next
Trying to set up from scratch, get cant connect to wi-fi errors, no sync
Any idea ?
(my network is fine, it's just these scales that are not playing nicely)
Moderator edit: format
03-14-2019 05:23
03-14-2019 05:23
It was set to mixed protocol, setting it to 802.11b sorted it
03-11-2019 04:23
03-11-2019 04:23
@SunsetRunner It's great to see you in our Fitbit Community! I'm sorry to hear that your Aria scale is not connecting to your network. Please let me know the following details:
- What is the make and model of your router?
- Is your router running the protocol 802.11b and bandwidth 2.4GHz?
- Have you changed your WiFi password?
These details will help me to proceed and assist you accordingly.
Looking forward to your response!
03-14-2019 05:23
03-14-2019 05:23
03-14-2019 19:53
03-14-2019 19:53
Why didn't it work when I changed the protocol to 802.11b? I have had weeks of runaround and no solution other than the recommendation to buy a new scale
03-15-2019 00:54
03-15-2019 00:54
The only other thing I did was use my PC to set it all up rather than Iphone
It's a convoluted set up, attach to device and then attach to your network
03-15-2019 04:11
03-15-2019 04:11
03-15-2019 08:07
03-15-2019 08:07
Choose on your router: 2.4 GHz, protocol 802.11 b and channel 11, that works
03-15-2019 08:14
03-15-2019 08:14
03-15-2019 15:57
03-15-2019 15:57
How did you change the setting to 802.11b ??
Did you do it on the router or on the computer ??
Thanks for your answer 🙂 smileyhappy:
@SunsetRunner wrote:It was set to mixed protocol, setting it to 802.11b sorted it
03-15-2019 21:48
03-15-2019 21:48
03-17-2019 03:47
03-17-2019 03:47
It was on the router setup. It's been fine for a week or so now
Think the later model of the scales supports more protocols, but I don't really want to upgrade to be honest
