Aria 2 - Trouble factory resetting
This has been a repeated issue for my Aria 2 trying to factory reset.
I have followed these steps multiple times:
Remove the batteries.
Press down on the small button directly above the battery slots.
While continuing to press down on the button, reinsert the batteries.
Be sure to press down on the button for at least ten seconds.
Replace battery cover.
Scale should now be reset.
1 REPLY 1
@SunsetRunner Welcome to our Fitbit Community. In order to avoid any confusion on my end, please let me know why you are trying to perform a factory reset. Is your Aria 2 experiencing any specific issue?
Thank you so much for your time with this.
See you later.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
