Aria 2 batteries drain fast
Help! I have put new batteries in my scale once a week for the last three weeks!.
3 REPLIES 3
Hi @SueJCR Welcome to our Fitbit Community. Regarding the battery draining issues that your Aria 2 has experienced, please try taking out the batteries, clean the contacts of your scale with a cotton swab and a little bit of alcohol in order to remove any dust from the contacts.
After this, put the batteries back in and see if they don't drain fast.
Hope this helps.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
I stepped on my scales this morning, and the battery indicated it was dead. I did as you suggested and it made no difference. At this rate I’m going through a lot of batteries!
@SueJCR Thank you for getting back and trying the recommended troubleshooting steps. Since the issue persists, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected and our Support team will be happy to follow up and assist you accordingly.
See you around.
