09-22-2020
18:41
09:45
JuanJoFitbit
09-22-2020
18:41
09:45
JuanJoFitbit
Hi All,
I got my Aria 2 less than one year, and the body fat percentage has been showing my percentage is somewhere between 8% to 12%; However, I have not exercised for the past 6-8 month due to COVID-19 lockdown. In the past, I have measured the body fat percentage at the gym, and it is usually showing about 19-23%, which was more reasonable to me.
I have reset the scale multiple times, but no change at all. Does anyone encounter this issue before? Or do I need to seek a refund of the faulty product?
Thanks in advance!
09-28-2020 09:44
09-28-2020 09:44
Hi @Edward.W, welcome to our Fitbit Community! I'm sorry to hear that your Aria 2 is not providing accurate body fat percentage readings. By the way, thank you for trying to get this issue resolved before contacting our forums.
Please re-calibrate your Aria 2 by weighing yourself 5 times in a row. Make sure that you step on the scale barefoot. After this, check out if the body fat readings are more accurate.
Keep me posted on the outcome.
09-30-2020 01:22
09-30-2020 01:22
Hi Juan.
Thanks for the reply. I have tried 5 times in a row many times over the past few months. Do you have any other way to fix the issue?
Or should seek for a refund?
Thank you.
Edward
