Aria 2: can it work on two different WiFi networks?
I have bought an Aria2 set of scales; I have sychronised it with my Samsung 10 mobile phone a my FitBit app.    I now want to take it with me between my two homes.  Will it be able to upload its data from either location, or will it only recognise the first WiFi through which it has already been sychronised?
   Or must I buy a second, separate set of Aria 2 scales for each location?
Silas C.
3 REPLIES 3
@SilasC, you will be able to use it on both networks, but when you change from one network to the other, you will have to use the app Aria2 account screen "Wi-Fi Setup" to connect it to the second network. Then, when you return to your other home you will have to repeat the process to put it back on that network.
Thank you   Is this the app (see my ScreenShot attached below) that you suggest that I should install on my Samsung mobile phone in order to log my data obtained from my Aria2 weighing scales?Silas C.
@SilasC, welcome to our Fitbit Community. The information that @USAF-Larry shared about the connection with 2 networks inquiry you had is totally correct.
Regarding the app you are having doubts with, I'm afraid that the screenshot was not included in your post. Please try to re-send the screenshot so we can assist you accordingly.
Please check out this post which explains how to add images to your posts.
Looking forward to your response.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
