Hi everyone,
I‘m posting because I didn’t find help anywhere else - any tips would be much appreciated, thank you!
As the title says: I got a used Aria 2 scale, reset it, and connected it to the Fitbit app. So far so good, it seems to sync with the app and when I go to the scale in the app, I can see the recent weigh-ins and that they have been tracked to me (and not to a guest). However, in the dashboard and daily stats, no data shows (neither weight nor body fat%). I have already restarted and updated everything..
Any ideas? Thank you!!
Hi @naida1 , @Kajolas & @RiekoC, Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your weight data logged into your Fitbit app.
If you see your weight in the Aria section, but you don't find it in the main board, maybe you just need to manage the tiles on the app. For reference see our help article How do I use the Fitbit app?> How do I add, remove, or rearrange tiles on the Today tab?
I have a similar issue. @DavidFitbit It's not that the weight tile is not showing. It's that the tile shows no data for the weight in even though Aria has clearly registered it. I have tried what you suggested and toggled the weight display on and off in the tile management area, but the result is the same.
I.e. It shows that there's no weigh ins at all today. When I go into the Aria icon, it does show the weigh ins.
See screenshots. I'm on iOS 26.2, and it's the same for my housemate on OS Android 16
