12-14-2018
09:45
08:45
12-14-2018
09:45
08:45
Hi! I've had the Aria 2 scale for a while now and this has happened pretty much the entire time but I never thought about the fact that it might be a bug.
Say I step on the scale, and it says I weigh 175.2. When I later look in my Fitbit app, it has recorded 175.1. Another day, it'll say 173.6, and then the app will say 173.5. It's always 0.1 higher on the scale itself than what gets sent to the app. I don't believe this happens with the fat percentage.
Any thoughts? Not a huge deal, since it's consistent, just peculiar.
Thanks!
Moderator edit: format
12-15-2018 05:26
12-15-2018 05:26
@Organica Welcome to our Fitbit Community! I'm sorry to hear that your Fitbit app doesn't show the same numbers as they appeared on your Aria itself. Please make sure that your phone has the most recent app version installed. If so, please try logging out of the app, restart your phone, open the app and log in. After this, weigh yourself 5 times in a row and see if the readings are the same on your Fitbit app as they are on the Aria itself.
Keep me posted on the outcome! ![]()
Best Answer12-16-2018 12:04
12-16-2018 12:04
12-17-2018 06:12
12-17-2018 06:12
@Organica Thank you for getting back! Thank you also for taking the time to try the steps listed above. Our team is currently looking and working on a fix to this issue and once we have a solution available, we'll make sure to post it in the Community.
Thank you for reporting this and we appreciate your patience and time with this.
05-08-2019 11:51
05-08-2019 11:51
Hi there! A followup that I just discovered - recently (for whatever reason), my scale has been weighing me in as a guest. In the app, I see my weight recorded as 170 (or whatever). As soon as I switch that reading from GUEST to me, I also see the number go from 170 to 169.9. Perhaps it's something weird with my account itself?
Best Answer05-09-2019 04:40
05-09-2019 04:40
@Organica I appreciate the information you provided about the behavior that your app has when switching the "Guest" weigh in to your user.
I'd like you to try setting up your Aria 2 from scratch. Please follow the instructions listed in this help article. After this, check out if the issue gets fixed.
Keep me posted! ![]()
Best Answer05-15-2019 15:52
05-15-2019 15:52
Best Answer05-16-2019 04:37 - edited 05-16-2019 04:37
@Organica Thank you for getting back and trying the recommended troubleshooting steps. Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions! ![]()
Best Answer05-19-2019 10:19
05-19-2019 10:19
@Organica and @JuanJoFitbit, what was the final disposition of this issue? I’m having the exact same problem. The weight recorded on the app is one-tenth pound less than the scale indicates. All the remedies you’ve suggested don’t work.
Any feedback is greatly appreciated. Thank you!
Best Answer05-19-2019 14:19
05-19-2019 14:19
I'm still going back and forth with the support team, but will let you know as soon as there's a resolution! They're having me calibrate the scale right now again, as Juan noted above so maybe it'll work this time? I'm still seeing the issue though.
05-20-2019 05:46
05-20-2019 05:46
@Michael400 Thank you for joining us in this thread! I appreciate the time you spent with the troubleshooting steps in order to fix the accuracy issue that your Aria 2 and Dashboard are experiencing.
Let me go ahead and send your case to our Support team so they can investigate further and proceed accordingly. They'll contact you via email soon.
@Organica Thank you so much for the update. I'm pretty sure that your case is in good hands and you will receive a response from our Support team soon.
I'll be around if you guys have more questions! ![]()
Best Answer05-20-2019 06:46 - edited 05-20-2019 06:48
@JuanJoFitbit, that would be fine if customer support opens a ticket for my case, but they should first focus on resolving @Organica‘s case before attempting to dedicate cycles on me. There’s no sense grasping at straws on two cases with the same issue. Solve one first, then use that knowledge to apply to the other. In the grand scheme of things, this is a very minor issue I can live with. 🙂 Thanks.
Best Answer05-21-2019 04:27
05-21-2019 04:27
@Michael400 Thank you for getting back! Regarding your inquiry, @Organica's case is already being handled by our Support as well as yours. You will be contacted via email soon.
I really appreciate your feedback and comments since this helps us to keep improving.
I really appreciate your patience and time with this. Don't hesitate to get back if you need further assistance.
Best Answer01-01-2020 21:17
01-01-2020 21:17
This same is is happening for me using a RENPHO Bluetooth scale. App records weight .1 lbs less than scale shows and scale app records.
05-31-2020 23:18
05-31-2020 23:18
Hi, was this ever solved? I have the exact same problem. Doesn’t bother me too much as it’s consistent and so small but would be interested in a fix if there is one.
Best Answer06-01-2020 09:45
06-01-2020 09:45
Best Answer06-01-2020 10:18
06-01-2020 10:18
@JuanJoFitbit, will this ever get resolved? Please be honest. Thanks.
12:05
09:32
JuanJoFitbit
06-01-2020
12:05
09:32
JuanJoFitbit
They got back to me via email when I reached out again - unfortunately not with a solution. I'll follow up there as well and report back!
Latest response - sounds like it's pretty low priority, but maybe still on their radar? Maybe.:
Thanks for letting us know about this issue and reaching back to Us.
Regarding you inquiry; At the moment some of our customers are till experiencing the same issue and We’re aware of it, but may not be able to provide a fix in the immediate future. We'll continue to monitor the situation, and keep our team informed of the impact to you and other customers. We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Please let us know if you have any other questions.
Moderator edit: merged reply
Best Answer07-17-2020 15:16
07-17-2020 15:16
having the exact same problem with my renpho
Best Answer01-16-2021 11:08
01-16-2021 11:08
This bug has been ongoing for *years* now.
Dear Fitbit, any resolution to this bug?
