02-12-2019
03:10
06:09
JuanJoFitbit
02-12-2019
03:10
06:09
JuanJoFitbit
I can see my weight, but I can't see any record of my BMI or body fat measurements in the Fitbit app. Where am I supposed to look to find this?
02-12-2019 04:01
02-12-2019 04:01
@jtpryan When you tap on your weight tile on the app dashboard, you will see your weight graph for the last 30 days above your weight log. Swipe the weight graph to the left to see the Lean vs Fat graph, then the Body fat %, then BMI. Tap on the arrows pointing apart and rotate your phone. You can choose among 1 wk, 1 mo, 3 mo, 1 yr, and all for all graphs.
I hope this helps.
Laurie | Maryland
02-14-2019 08:26
02-14-2019 08:26
@jtpryan It's great to see you in our Fitbit Community! I'm sorry for the late response. However, I'd like to follow up and would like to know if the issue persists or if you are able to view your BMI and body fat weigh ins after following the great advice that shared my friend @LZeeW.
See you guys later!
01-11-2020 01:00
01-11-2020 01:00
Ok so I have just purchased the Aria air and i can see all the little icons for things you should be able to see on scale, however I cannot. Figured out how to change from lbs to kg, but cant figure out how to see top lines. Much frustration 😞
01-12-2020 03:58
01-12-2020 03:58
@Rachie16 There is a button on the underside of the scale. A light touch will change among the weight unit choices.
Laurie | Maryland
01-16-2020 11:42
01-16-2020 11:42
02-20-2020 13:27
02-20-2020 13:27
How do I get the scales image back?
11-05-2020 09:38
11-05-2020 09:38
Hi I have the same problem! I can only see BMI etc on my watch but not on the scale itself even though the grey icons are there. How can I see all the info on the scales itself?
thanks
