12-06-2017
06:48
04:01
JuanJoFitbit
12-06-2017
06:48
04:01
JuanJoFitbit
I recently completed an in-depth bio metrics analysis using a BodPod, the most accurate commercial analysis on the market, and learned I had 17% body fat. The Aria 2 tells me I have 29.5% body fat. I am a fitness instructor and muscular body type and believe the first number is more accurate. Is anyone else having this same issue? Or does my Aria 2 need to be returned?
01-22-2020 12:44 - last edited on 01-30-2020 12:13 by LiliyaFitbit
Not sure, I use a RENPHO Scale. $26.99 on Amazon.
01-30-2020 17:27
01-30-2020 17:27
My body fat from In Body has consistently been 15.9%-16.2% and then my Aria 2 (new) put it at 24% yesterday. Which I know isn't close to true. I've tried taking out the batteries, changing it to LEAN mode, storing it on its sides, but nothing yet to get the BF% back to the range *I Know* it should be. WTF, Fitbit?
01-30-2020 17:44
01-30-2020 17:44
02-01-2020 15:17
02-01-2020 15:17
I was having a similar problem. Body fat indicating about 10% higher that reality. After reading a bunch of heated posts about gender selections and folks criticizing the scale as defective, i came across a post about simply just resetting the scale. Its a bit of a pain as you have to reconnect to your wifi network but after simply resetting the scale, re-connecting the scale with the same wifi network and oh, fresh batteries, it worked. my body fat is now indicting where it should, a full 10% lower than it was prior to the reset. The reset is completed by taking out the batteries for 10 seconds, visiting https://www.fitbit.com/scale/setup on your computer. follow the on screen instructions and voilà. Warning, if you are not familiar with how to setup wifi and are not comfortable resetting your scale ask someone tecky to help you as you will lose connection to your scale if you reset it and cant figure how to re-connect back to your network. Good Luck!
02-02-2020 12:36 - last edited on 08-31-2020 19:44 by LiliyaFitbit
yep, doesn't work for me. still showing bodyfat at least 10% higher than
last accurate reading 2 weeks ago using InBody.
02-02-2020 12:39
02-02-2020 12:39
02-02-2020 13:19
02-02-2020 13:19
02-02-2020 13:30
02-02-2020 13:30
03-10-2020 22:27
03-10-2020 22:27
Mine is the other way around ... It says I have 14.2% body fat that I replaced the battery when I used to have 29,2
04-28-2020
19:05
05:13
JuanJoFitbit
04-28-2020
19:05
05:13
JuanJoFitbit
Yes, me too, I do weights training and I got measured at my gym they said my body fat was 19.9% the aria 2 scale says I’m 34%, Could it be it’s mistaking muscle for fat% ?
Same problem for me, I’m in Australia so expensive postage to return from here. Should have bought a $20 scale from Kmart, would have done the same job.
Moderator edit: merged reply
04-28-2020 19:44
04-28-2020 19:44
04-29-2020 06:51
04-29-2020 06:51
After spending some time trying to understand this, I think the Aria 2 is using a calculation largely based on BMI (height/weight) that it supplements from whatever basic measurement (if any) it gets from its "sensors" ref impedence. The InBody scanner uses impedence, but in addition to foot plates you hold sensors in your hands, and for that reason I believe it gives more accurate readings. I could only get the Aria 2 to approximate my InBody readings by tweaking my height (higher) than what it really is. For example, I'm really 173cm and only by setting my height (in Settings on my profile) to 176cm did the Aria start to get in the range of my InBody body fat %s. I also had to set it to "lean." I haven't done an InBody since January (thanks to covid), but will check to see how Aria 2 is doing next time I do one.
04-29-2020 08:23 - last edited on 08-31-2020 19:45 by LiliyaFitbit
Interesting, let me know if that helps. It’s just ridiculous to have to tweak so many things to get an accurate reading on a $140 scale. I should’ve just gotten the $40 scale from Bed Bath and Beyond.
Best regards,
04-29-2020 11:36 - last edited on 08-31-2020 19:45 by LiliyaFitbit
Wow, you shouldn't have to manipulate your height to get correct measures.
I think they should do a recall on these scales.
05-14-2020 23:41
05-14-2020 23:41
I bought the Aria 2 last week and am pretty disappointed. It seems to give me a correct weight, but the body fat percentage is way off. I have tried to recalibrate many times. I’m a fit woman who wears a size 4. I cycle almost every day, get 70-100k steps in a week and do daily yoga and the scale is telling me I’m obese. Not exactly what I thought I was spending so much money on.
05-14-2020 23:50
05-14-2020 23:50
05-14-2020 23:57
05-14-2020 23:57
05-15-2020 06:37
05-15-2020 06:37
05-15-2020
06:52
07:20
JuanJoFitbit
05-15-2020
06:52
07:20
JuanJoFitbit
Wow, sounds way off. I think BMI measurement is bogus because of different body shapes and height. The Aria scale overstates. Keep up the great work, you sound like a fitness guru!
I hear you. I’m going to give mine back to my kids that gave it to me as a present.
Sent from my iPhone
05-15-2020 12:22 - last edited on 08-31-2020 19:46 by LiliyaFitbit
Same thing with me. I’m very active. 13,000 steps a day. Lost fat from my waist and thighs and my body fat percentage went up. I’m 5’7”, 130 lbs. Size 4 and scale says body fat is 31%. The machine at my gym used to read 24-26% depending on my hydration. Seems way off to me.
Best regards,
