12-07-2019 06:55
12-07-2019 06:55
I've noticed that there are at least two model numbers for the Aria 2. I've seen one as FB201, which I assume is earlier, and the FB202BK. I also assume the BK means black, and that the FB202 is the newest version? I don't want to buy and older version that hasn't had the "kinks" worked out.
Any insight would be appreciated.
Thanks!
12-07-2019 08:48
12-07-2019 08:48
@Gavacho FB201 is the original Aria scale. It is not available from the Fitbit store or other sites like Amazon and Best Buy. FB202BK is the black Aria 2 and FB202WT is the white Aria 2.
I hope this helps!
Laurie | Maryland
12-07-2019 08:48
12-07-2019 08:48
I hope this helps!
Laurie | Maryland
12-07-2019 10:26
12-07-2019 10:26
Thanks, Laurie! I figured as much...
12-09-2019 04:12
12-09-2019 04:12
@Gavacho I'm sorry for the late response. However, let me welcome you to our Fitbit forums.
I'm glad to hear that you managed to find the information about the model of the Aria scales. We appreciate your interest in the Fitbit products.
As a side note, I'd like to invite you to visit our Discussions board, where you can share your experiences, meet people and create new topics.
Thank you for your help @LZeeW.
I'll be around if any question arises.
12-22-2019 10:17 - edited 12-22-2019 10:41
This FB number is also part of the FCC registration.
Go to the FCC search page. Drop the number in and you will get the exact model and radio specifications.
12-22-2019 10:25
12-22-2019 10:25
Thanks for the reply, but I noticed that different numbers were listed on fitbit.com and other sites. Out of curiosity, why would they have different FCC registrations if they were the same model? Thx
12-22-2019 10:40 - edited 12-22-2019 10:44
Because as @LZeeW has explained @Gavach they are not the same scale.
The FB201 was released around 2004 or earlier. This is the Aria first model
The FB202 is for the scale that was release 2 years ago. This scale comes in both black and white. Each with its own ID
Then there also is the FB203 which is the Aria Air
To sum up, there are 4 different models of the Fitbit scales.
