11-20-2019 19:14
11-20-2019 19:14
Hi. I was given a second hand set of aria 2 scales however I can get it to be picked up on the app or Bluetooth. I’ve done a factory reset on the scales and it turns on saying setup active but when I go i to the app it doesn’t find the scales and neither does my Bluetooth??
11-21-2019 03:19
11-21-2019 03:19
@Misskama87, welcome to our Fitbit Community! I'm happy to assist you with your Aria 2 since it's not being recognized by your phone's Bluetooth. By the way, thank you for trying a factory reset before contacting our forums.
Please make sure that your phone has the most recent Fitbit app version installed. If the app is up to date, try logging out of your Fitbit account, restart your phone, open the app and log in. Finally, try the setup process one more time as described in this help article.
Keep me posted on the outcome! 😀
11-21-2019 05:49
11-21-2019 05:49
11-21-2019 08:05
11-21-2019 08:05
If you have 4 batteries @Misskama87 then you have the original Aria scale and not the Aria 2.
11-21-2019 10:10
11-21-2019 10:10
11-21-2019 10:31
11-21-2019 10:43
11-21-2019 10:43
11-21-2019 10:51
11-21-2019 10:51
So its done but not showing as a device on my app, is that correct?
11-21-2019 12:48
11-21-2019 12:48
It should show up as a connected device on the app. Did any of your weighings sync to your account?
01-08-2021 13:42
01-08-2021 13:42
Hello. I am having the same issues and have tried all of the steps listed above. Help? Thanks
01-11-2021 08:41
01-11-2021 08:41
Hi @Medic1048, thank you for joining us in this thread and our Fitbit Community. I would like to know if your Aria 2 shows any error message when trying to connect with your phone's Bluetooth.
In the meantime, try taking out the batteries for 15 seconds and put them back in. After this, please make sure to follow the setup process as described in this help page.
Looking forward to your response.
01-11-2021 14:20
01-11-2021 14:20
01-12-2021 08:59
01-12-2021 08:59
Hi @Medic1048, thank you for getting back and trying the steps previously shared. Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
01-13-2021 01:55
01-13-2021 01:55
@Medic1048 you need to use the Fitbit app to setup a scale, your phones Bluetooth, at best will reject.
04-02-2023 14:24
04-02-2023 14:24
Same
aria 2 found but refuse to connect
06-06-2023 20:13
06-06-2023 20:13
I’m having the same issues. Has your issue been resolved?
