12-31-2019 00:05
12-31-2019 00:05
I’ve just bought the aria 2 scales, I’ve set them up and they’re logging the weight onto my app but it’s storing it separately to my weight log on my inspire HR profile if that makes sense. When I click on my profile there’s a separate bit for scales and my watch- the weight is being logged under scales so I have to manually type it into my weight log on the “today” section of my inspire HR. Is there a way to get the weight to sync into there?
Best Answer01-04-2020 13:12
01-04-2020 13:12
Your scale doesn't sync into your inspire HR. Both the scale and the inspire should sync into your Fitbit account.
When you setup the scale you choice an icon to represent you, after weighing your self. Tap the left or right pads to select this icon so the reading goes into your account.
I think your seeing the scale record you as a guest and you will want to re-assign it to your account.
Why is my Fitbit scale recognizing me as a guest?
