08-04-2019
09:50
08:45
08-04-2019
09:50
08:45
The first few times I used the Aria 2 it displayed the FEET icon and then the one that tells you to step off.
After moving the scale to a permanent location, every time I use the scale it immediately shows my weight, BMI and body fat percentage. I no longer see the FEET icon displays.The data does get synced with my Fitbit app.
Any reason why the Aria 2 is doing this? What icons should appear every time you weigh yourself?
08-05-2019 04:24
08-05-2019 04:24
@jghfit it's great to see you in our Fitbit Community! I'm happy to assist you with your inquiry about the "Feet" icon that your Aria 2 used to display. Please restart your Aria 2 by taking out the batteries for 15 seconds and put them back in. After this, weigh yourself 5 times in a row and see if the "Feet" icon appears again. If the icon doesn't appear, this doesn't affect the functionality of your scale nor the readings accuracy.
As a side note, I'd like to share this help article which explains the meaning of each icon that the Aria 2 shows.
I'll be around if more assistance is needed! ![]()
Best Answer08-05-2019 04:24
08-05-2019 04:24
Best Answer08-05-2019 18:53
08-05-2019 18:53
What’s the reason for weighing 5 times in a row? I restarted the scale but only weighed myself once. When I weighed myself later it was acting w/o the feet. The feet only showed the first time. I will restart again and weigh myself 5 times in a row to see what happens. But why the 5 times in a row.
Best Answer08-06-2019 04:25
08-06-2019 04:25
@jghfit thank you for getting back! Regarding your question, weighing 5 times in a row after restarting the scale, this re-calibrates the Aria 2 internally.
LEt me know how it goes and if more questions arise! ![]()
Best Answer08-07-2019 08:14
08-07-2019 08:14
I tried it again today and the first time I used the scale after restart I saw the feet. All subsequent attempts to reach 5 times just displayed the weight, BMI and Body Fat as before. It showed my icon at the end and confirmed the synch.
I suspect the Aria 2 is operating as designed and it only tells you to step off during the initial calibration that is being performed.
