10-02-2021 00:48
10-02-2021 00:48
My scale is giving me weight only, but used to provide the other metrics. I’ve done a manual reset but still getting the same issue. I have seen similar Qs in the forum but none with any accepted fixes.
Any advice much appreciated!
10-03-2021 10:08
10-03-2021 10:08
I hope you're doing well, @Benob.
I appreciate the details provided and restart performed. You can select on the Fitbit app if you want to see your BF% and BMI on the Aria 2 by doing the following:
1. Tap on your profile's picture.
2. Select Aria 2
3. Tap on People Using This Scale.
4. Select your name and choose to show body fat percentage and BMI on your scale.
Thanks for stopping by, see you around!
10-07-2021 23:17
10-07-2021 23:17
Thank for this. I did have BMI switched off and this is now showing. BF% was turned on though and just showing ‘-%’ still. Checked and my height etc. is all still recorded correctly in the app.
10-10-2021 07:05
10-10-2021 07:05
Hi, @Benob.
Thanks for the update. If your Aria 2 is not showing BF% make sure that you're weighing-in with bare and dry feet (don't wear shoes or socks when you stand on the scale). You can also clean the Aria 2's surface with a moist cloth, and then dry it off with a different cloth.
Catch you later.
10-10-2021 07:14
10-10-2021 07:14
Thanks, I was trying barefoot. Will give it a good clean and see if it makes a difference.
10-15-2021 10:00
10-15-2021 10:00
Given the scale a good clean but still no BF reading being given. Not sure if there’s anything else to try?
10-17-2021 11:32
10-17-2021 11:32
Hello, @Benob.
I appreciate the update and troubleshooting performed. Is the Aria 2 recognizing you when you weigh in? If the scale is recognizing you as Guest, that could be the reason why you don't see BF%. In case that the scale is recognizing you but still not showing your BF%, I recommend you to contact our Support team by chat or calling them so they can check with their tools if something is wrong with your Aria 2.
See you around.
10-17-2021 11:57
10-17-2021 11:57
Thanks - yes, it is recognising me. Will try the support.
