10-13-2018
00:51
06:17
JuanJoFitbit
10-13-2018
00:51
06:17
JuanJoFitbit
My Aria 2 has been working fine for 4-5 months no problem. It would sync immediately after weighing with the Fitbit app. A few days ago a connection error popped up. I run through WiFi set up, it says connected, the sync timer sign displays, it then comes up with connection error with a sad face. It’s been like this for the past c3 days. I’ve run the WiFi set up 15-20 times, tried pulling out the batteries for 20-30 mins, still same problem. That said, each day at c430am BST it syncs and updates my Fitbit app. Can you please investigate and or let me know what I can do to remedy. Thanks
02-11-2019 07:07
02-11-2019 07:07
@AustinLloyd I'm sorry for the late response. However, I'd like to follow up on this issue and would like you to try one more workaround if you guys haven't done so. Please restart your routers, make sure that they're running the protocol 802.11b and try the setup process one more time. Let me know how it goes.
@Liverpool-Ruth Thank you so much for sharing your feedback! Please don't hesitate to get back if you need further assistance.
Best Answer02-11-2019 07:38
02-11-2019 07:38
Best Answer02-12-2019 06:11
02-12-2019 06:11
@Liverpool-Ruth Thank you for letting us know the information. I completely understand that you wouldn't change the settings. I'm sorry about the inconvenience that this caused you.
Best Answer02-12-2019 09:31
02-12-2019 09:31
Best Answer02-13-2019 05:31
02-13-2019 05:31
@Liverpool-Ruth I appreciate your feedback. I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Don't hesitate to get back if you need further assistance! ![]()
Best Answer02-20-2019 06:03 - edited 02-20-2019 06:03
So randomly yesterday my Aria 2 synced fine again at point of weigh in. Twice consecutively......... This morning, connection error again.......... 😞
I wish this thing would just work as it should.
02-20-2019 10:15
02-20-2019 10:15
Best Answer02-26-2019 06:09
02-26-2019 06:09
@Carrie273 Since the issue persists, let me send your case to our Support team and they'll be happy to follow up and assist you accordingly. You will receive an email from them soon.
@Liverpool-Ruth I'm sorry for this inconvenience. However, i'll be around if you need further assistance.
Best Answer07-13-2019 03:30
07-13-2019 03:30
My new Aria2 was having the same syncing issues with my Virgin Media Wifi, I fixed it (touch wood) by disabling the 5ghz wifi channel in the VM router config leaving just the 2.4ghz channel active.
For those who want to use both wifi channels, possible workarounds may include:
1) assigning a separate SSID to the 2.4ghz channel and using that in the Aria2 wifi setup.
2) creating a guest network that has the 2.4ghz channel active & and the 5ghz disabled.
I will probably end up going with 2 but have had no issues with just using the 2.4ghz connection so far.
Doesn't explain why the scale still managed to sync once every 24hrs at 11:23 am ??
Just happy it working as expected now and move on.
Hope it helps.
Best Answer07-13-2019 07:27
07-13-2019 07:27
Best Answer07-15-2019 04:36
07-15-2019 04:36
Best Answer07-22-2019 03:47
07-22-2019 03:47
Hi Juan,
Have you worked out a fix for this issue with Aria 2 scales not working correctly with Virgin wifi or do I need to return my scales for a refund?
Best Answer08-14-2019 03:53
08-14-2019 03:53
Well we’ve just got back from holiday and have come back to this problem for no reason. Syncs once a day at 10:53. No changes, just random. I think Fitbit need to solve this as many people are obviously having the same problem.
Best Answer08-14-2019 03:59
08-14-2019 03:59
Best Answer08-17-2019 13:48
08-17-2019 13:48
I am facing the same problem.
Fitbit must fix this.
So sad!!!!
Best Answer08-09-2022 04:14
08-09-2022 04:14
Facing the same problem with my Aria2. Was working fine until recently. Not change whatsoever on internet settings.
