02-19-2018 23:33 - last edited on 09-04-2019 08:45 by MatthewFitbit
I have been using the Aria 2 for a few days now and I have received so many different readings on both body fat and weight within a space of a couple minutes (i weigh same time every morning). My profile settings are all correct and i have recalibrated it just in case and still i get a varied reading. Is this a hardware fault?
Appreciate your help and thanks!
11-11-2020 13:43
11-11-2020 13:43
I've got the same problem as Ted. I weigh myself, then myself with my dog, every morning. She's elderly, and not eating well, so I need to keep an accurate record of her weight. I don't always figure her weight right away. When I go back to my app, click on my icon, then Aria, then recent weigh-ins, I can use my weight and the guest weight to calculate hers. BUT...when I just check my weight in the Weight section of the app's main screen- it doesn't match the weight I just looked at under Recent Weigh-Ins! How can this be? I cannot track my weight, nor hers, without accurate numbers. WHICH WEIGHT IS THE CORRECT WEIGHT? AND IS THE GUEST WEIGHT CORRECT UNDER WEIGH INS? I don't know which weight number coincides with my Aria readout- I'd assumed the numbers in the app matched. But which numbers?
11-11-2020 21:05
11-11-2020 21:05
