09-04-2019
06:50
14:53
09-04-2019
06:50
14:53
Can someone tell me the difference between the Aria 2 and the Aria Air? I read the press release from investor.fitbit.com and a few different articles on websites and I can't seem to find the difference. They both use BT, they both measure BMI. Why is one half the price of the other?
TIA!
09-04-2019 07:22
09-04-2019 07:22
Hi, @phatRik! Aria 2 automatically syncs through WiFi and measures body fat (BMI is just a calculation). Aria Air will have to be manually synced with your app via Bluetooth and cannot measure body fat, it will just tell you your BMI based on your account. It's basically a slimmed down version of the scale.
MakMak | Community Council
09-04-2019 07:22
09-04-2019 07:22
10-10-2019 12:02
10-10-2019 12:02
So it's just an overpriced scale that can "automatically" write the numbers in your app? What's the benefit?
10-12-2019 17:41
10-12-2019 17:41
The Aria 2 can tell you your body fat percentage. So say you’ve been working out and dieting but you gained weight rather than losing it. Using Aria 2 can show you that you lost body fat, but gained muscle. Helpful for some people, others couldn’t care less. But that’s the difference. Aria air doesn’t tell you your body fat percentage.
10-27-2019 22:22
10-27-2019 22:22
Well the Aria has a historically crappy wifi solution so not sure its worth the difference for wifi.
10-28-2019 04:16
10-28-2019 04:16
Drewesq,
That was the original Aria scale manufactured with a pretty much obsolete wireless spec. Didn't Fitbit inherit that product from another company? I have recently purchased the Aria2 scale and there is no comparison the wireless setup just work and has been rock solid. Also I have not had any issues with the battery life. My Fitbit dashboard is still showing a full battery after a couple of months. I do leave them in the same position though on a level stone floor. I think if you keep moving them they recalibrate each time and that probably uses up battery power.
11-08-2019 04:54
11-08-2019 04:54
In general my issue with quick drained batteries was actually to clean the glass surface very well and to use compessed air and/or vaccum cleaner to clean the "feet" of the scale from any home collected dust and fine particles ... that resolved any isues with my Aria 1 😉
Cheers
11-08-2019 19:29 - last edited on 11-10-2019 10:45 by LiliyaFitbit
My issues are with the wifi. I can not sync my daily weights.
12-20-2019 11:40
12-20-2019 11:40
Maybe the air is a semi good faith effort to make up for the fact that the aria for $150 was a crappy design that fails after 2 years because of a two cent plastic piece that fitbit refuses to replace or even acknowledge. Seriously bad experience
01-08-2020 03:59
01-08-2020 03:59
Although I'm a big fan of Fitbit. But that only applies to the fitness trackers. But not the scales.
Your question will be answered in my comparison between Fitbit Aria 2 and Aria Air. There you will find all differences and my opinion or recommendation.
01-08-2020 20:28 - edited 01-08-2020 20:30
Yea. Now I feel like I got ripped off.
01-17-2020 20:38
01-17-2020 20:38
01-20-2020 06:21
01-20-2020 06:21
As a Disappointed Customer... I have to agree.... I acquired few of these expensive scales: Aria ; Aria 2; it's just frustrating to have it working with the WiFi and not accurate as it's claimed to be! 😞
01-20-2020 06:25
01-20-2020 06:25
I'm shopping and it looks same version of their Aria hardware, sold by other vendors, which is coming out China is priced in some case down to less than $30.00 USD. So why paying all this much money to FitBit for their crappy Aria when not even their crappy Aria connection applications works... 😞
03-20-2020 04:12
03-20-2020 04:12
I'm glad I've read this post I'm still in my 30 day return window with Amazon. 😕
03-20-2020 07:25
03-20-2020 07:25
😞 joining the "I feel ripped off" club.
04-25-2020 11:31
04-25-2020 11:31
I am returning my air. There are better cheaper scales with body fat % included. I don’t know why fitbit included a bmi and bf% on the display if we can’t use it.
06-18-2020 11:13 - edited 06-18-2020 11:16
The Aria 2 has WiFi and the Aria Air does not have WiFi. The Aria Air only shows BMI, not body fat percentage.
10-19-2020 11:17
10-19-2020 11:17
OK, since some of you feel the need to comment about something you don't own, let me state that I own the Aria 2 and it works flawlessly (I've had it for quite a while). The Wifi always works and yes, it may not seem like much but having it automatically populate to your Fitbit app is very nice and it can also track more than one scale user. Whether you actually use BMI or not, it's nice to have simply because it's another indicator of whether you're going in the right direction. No, I don't think the Aria Air is worth the price of admission. Typical story - you get what you pay for.
10-20-2020 06:07
10-20-2020 06:07
I would echo what Connie said. I actually have the Aria 1 and the wifi works on my eero mesh network fine. (And it's worked on many other networks throughout the years). I feel like the weight fluctuates as expected as long as it's on a firm level surface (ie: not in tile groves) and I stand on it in an even way. Getting to see my weight go up and down over the course of the last eight years is both a blessing and a curse 🙂
