08-04-2020
		20:05
		05:18
			JuanJoFitbit
		08-04-2020
		20:05
		05:18
			JuanJoFitbit
I had to reset my aria 2 because it wasn't sending my weights to the app. In any case it is now but im concerned about its accuracy. This morning I was at 247 lb but after the reset I weighed in again at 243 lbs. As much as I would've loved that I don't thing it is right. Anyone seen this or know a way to ensure it is right?
08-26-2020 05:17
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              08-26-2020 05:17
Hi @Ryan10102, welcome to our Fitbit Community! I'd like to follow up and help you with your Aria 2 since it's not providing accurate weight readings. By the way, thank you for troubleshooting this issue before contacting our forums.
Please re-calibrate your Aria 2 by weighing yourself 5 times in a row. Also, check out and follow the steps listed in this help article, under the subject "How can I get the most accurate reading on my Fitbit scale?". Finally, monitor your scale for the next 48 hours and see if it provides accurate readings.
Keep me posted on the outcome.
