Aria 2 weight goes up each time I step on it
I weigh myself every morning. If I step on the scale more than once the weight will consecutively go up.
For example: 125, 126, 128, 129, 131
I've had it for a year and it's always done this.
Which one is right?
Moderator edit: format
1 REPLY 1
@Chris276 welcome to our Fitbit Community! I'm happy to assist you with your Aria 2 since it provides higher readings each time you weigh yourself.
I'd like you to restart your Aria 2 by taking out the batteries for 15 seconds and put them back in. Once you've done this, weigh yourself 5 times in a row and see if the issue gets fixed.
As a side note, make sure that your scale is placed on a hard surface and you stand on it barefoot.
Keep me posted on the outcome! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
