12-29-2017
00:47
08:45
12-29-2017
00:47
08:45
how do you get the aria 2 readings to show on your Fitbit dashboard (iOS)?
I can only see them if I go into the individual aria 2 device section on my app.
11-15-2018 06:36
11-15-2018 06:36
@Hlkleinberg A warm welcome to our Fitbit forums! I'm sorry that your Aria 2 didn't show your weights. However, I'm so glad to hear that you managed to get this issue resolved. Thank you for sharing your feedback.
As mentioned in my previous post, I'd like you to give a chance to participate in our Discussions board where you can meet more people, tell your stories and start your own topics.
Don't hesitate to get back whenever you need assistance!
11-20-2018 17:43
11-20-2018 17:43
I tried this as well, and after restarting my phone it showed the synced weight was on the dashboard when I opened the app!
11-21-2018 05:22
11-21-2018 05:22
@LivvDown Thank you for participating in our Fitbit Community! I'm glad to hear that your weight showed on your Dashboard after you restarted your phone. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often!
11-29-2018 13:59
11-29-2018 13:59
Same problem...can not get the weight to show on app. Log out. Log back in. Pull batteries etc...
No error notices etc.
12-04-2018 03:42
12-04-2018 03:42
@kfi52 It's great to see you new faces in our Fitbit forums! I'm sorry for the late response by the way. However, I want to follow up on this issue and would like you to make sure that your phone has the most recent app version installed. After this, try weighing yourself 5 times in a row and after those weigh ins get synced, go to your Fitbit app, tap on the "Weight" tile (the one that has a little scale as an icon) and see if the readings appear.
Keep me posted on the outcome!
12-12-2018 00:47
12-12-2018 00:47
I am also facing with this same issue. Just got a new Aria 2, and it is syncing to my iphone. The weights are showing up under the device section under "Recent Weigh-Ins". However, they are not showing up on the App Dashboard immediately. If I restart the app (kill it and start), it will then reflect on the dashboard.
After a weigh-in, is the latest record suppose to show up on the dashboard immediately? (for example, after a run with my FitBit Charge 2, when I open the App, it will sync immediately and update the dashboard. This is not happening for the Aria 2.)
I can't be always killing the app and restarting it. It doesn't make sense. Please advice.
12-14-2018 03:42
12-14-2018 03:42
@MelvinL Thank you for joining us in this thread! I'm sorry to hear that your Aria 2 takes a while when syncing your data to the Fitbit app. Please make sure that your phone has the most recent app version installed. If so, please restart your Aria 2 by taking out the batteries for 15 seconds and put them back in. After doing this, weigh yourself 5 times in a row and see if those readings get synced immediately.
Let me know how it goes!
01-08-2019 06:03
01-08-2019 06:03
I was able to get it to work by going to the area of the fitbit app where devices are listed, click on Aria, then under the General section, click Users and make sure your account is selected. Mine had "Guest" listed and selected, once I selected my account, the fitbit app showed my weigh in results.
01-08-2019 10:20
01-08-2019 10:20
Thanks, @oskee, for that very clear information, which I am sure will help others.
Welcome to the forums!
01-11-2019 08:50
01-11-2019 08:50
I can confirm this Problem.
Aria 2 does not show measured weight in main dashboard on app, yet shows in Aria 2 settings for Aria 2, in app.
It only worked right after setup, once.
scale is within wifi range and checkmarks measurement.
Attempted resolutions (IOS):
- verified app is up to date
- restarted phone, and thus app
- removed tile, closed app and added back to dashboard, restarted phone
None of this worked and since I can see the measurements in the Aria 2 settings I am pretty sure you have a bug.
Also note multiple users have this issue.
Please confirm defect and resolve.
01-15-2019 05:11
01-15-2019 05:11
I've done everything you said and I still only see my weight if i physically click on the Aria 2 icon. It is not showing up on my dashboard/weight tile.
01-19-2019 20:54
01-19-2019 20:54
Did you end up figuring it out? Mine won’t either! It’s under the scale in weigh ins and hasnmu icon but doesn’t go on the dashboard!!??
01-20-2019 09:06
01-20-2019 09:06
01-24-2019 03:29
01-24-2019 03:29
@Gboerman I'm so glad to hear that your weigh ins are logging to your Dashboard now. Thank you for posting the update here. Don't hesitate to get back if you see something unusual and I'll be glad to assist you.
@Kristina1st @Ldietr01 Welcome to our Fitbit Community! I'm sorry for the later response. However, I'd like to follow up on this issue and would like to know if the issue persists or if your weigh ins are getting logged properly now.
See you all later!
06-17-2019 14:28
06-17-2019 14:28
Hi! I'm having the same issues as the others except the problem has not resolved, despite following all the posted suggestions. The weigh-in weights aren't showing up in the dashboard. The fat percentage is not showing at all on the scale, nor the BMI. The wireless connection is established. Please help--thanks!
06-18-2019 04:14
06-18-2019 04:14
@eatyourbeets thank you for your participation in the Fitbit Community! I'll be glad to assist you with your Aria 2 since it's not showing your weigh ins, body fat percentage nor BMI. By the way, thank you for troubleshooting this issues before contacting our forums.
I would like to know what troubleshooting steps you tried so I can avoid providing the same information.
In the meantime, please check out this help article, under the subject "What does the Aria 2 measure?". Also, make sure that your scale is placed on a hard surface and you stand on it still when you step on it.
I look forward to your response!
10-01-2019 15:25
10-01-2019 15:25
Hi, I hope someone can help me, I have a Fitbit Charge HR. As I was resetting my dash board accidentally deleted the weight word from the dashboard, how do I reinstall that.
11-20-2019 07:18 - last edited on 03-02-2020 17:13 by LiliyaFitbit
i never have to do it manually, the question is why suddenly the weight on my Aria doesn’t show on my Fitbit app? The whole point of having the Aria is so it would show on the Fitbit app, not to write it manually, I could have done that with s $20 scale
Moderator edit: format
11-20-2019 07:27 - last edited on 01-31-2020 16:14 by LiliyaFitbit
I never have to do it manually, the question is why suddenly the weight on my Aria doesn’t show on my Fitbit app? The whole point of having the Aria is so it would show on the Fitbit app, not to write it manually, I could have done that with s $20 scale
12-03-2019 10:58
12-03-2019 10:58
Does your Aria weigh in show on the Fitbit dashboard on fitbit.com login? I had the same problem where it did show on the browser dashboard but not the iphone app (though it did show as recent weighs-ins on the Aria icon on the app) So obviously it was syncing partially so the app is the problem, not the scale. I checked to make sure I had current update of app which I did so then I deleted the app and reinstalled it. It fixed my problem. Some people have said just restarting your phone works though not in my case.
