Aria 2 won't connect to Google Nest Wifi
Aria 2 will not connect to Google Nest Wifi
  •  I have confirmed Google Nest Wifi satisfies the Aria 2 network requirements
    •  Google Nest Wifi supports Wireless 802.11b/g/n
    • Google nest wifi supports both 2.4 GHz standard and 5 GHz wi-fi bands
    • Google Nest wifi supports WPA2
    • Automatic (DHCP) IP is properly configured
  • I have the latest iOS updates on my iPhone 16 Pro Max
  • I have refreshed my Fitbit App on my phone by removing Aria 2 from the app, uninstalling the app and reinstalling the app from the App Store
  • My network password does not have any special characters. It's Alpha Numeric only
  • I cannot use a laptop to set it up as others have successfully because the FitBit windows app no longer exists.
  • I am using Google gmail account to log into fitbit
  • I have factory reset the Aria 2 scale
  1. I put the scale in discovery mode
  2. Add Aria 2 in Fitbit app
  3. Enter the code displayed on the scale in Fitbit app
  4. On "Connect your Aria 2 to Wi-Fi" screen I get "No networks found", "check your wi-fi connection, then try again
  5. I click "okay" and then "not now" to acknowledge I can't connect to wifi
  6. It says my Aria 2 is ready
  7. Back on the "Connected to Fitbit" screen I click my Aria 2 device
  8. Fitbit app hangs, so I force restart the app
  9. I go back to "Connected to Fitbit" screen and select the device again
  10. "Wi-Fi Network" is blank. No settings.
  11. I click "Wi-Fi network" and then "next" to acknowledge Wi-Fi setup screen
  12. And error immediately pops up "Wi-Fi Problem" There was a problem with Wi-Fi.
0 REPLIES 0
