12-27-2020
02:30
06:13
JuanJoFitbit
12-27-2020
02:30
06:13
JuanJoFitbit
I can't get my aria2 to connect to a network. I've moved house and have a plusnet one router. I've tried turning off 5GHz. I get to the finding networks screen, get a 'there's a problem try again later' flash up and that's it. I deleted the aria2 and re added, it synced briefly but now back to no WiFi on the scale.
12-27-2020 13:55
12-27-2020 13:55
Is your new router compatible?
Networking Requirements
Aria 2 connects directly to your home’s Wi-Fi network and supports the following
network configurations:
• Wireless 802.11b/g/n, 2.4 GHz standard
• WEP / WPA / WPA2 personal security
• Automatic (DHCP) IP setup (static IP configuration not supported)
Aria 2 requires an 802.11b/g/n-compatible network to connect and sync your scale
data to your Fitbit account.
12-28-2020 11:45
12-28-2020 11:45
Thanks for replying. I believe my router supports all of these requirements. I can't see why it won't see the network. Any network at all! It didn't even show my neighbours.
Janette.
12-30-2020 10:59
12-30-2020 10:59
Anyone got the same issues?
01-04-2021 07:07
01-04-2021 07:07
Yes. I got a new router, WPA has same name Wi-Fi is open and unlocked. aria says it’s connected at startup but after weighing Wi-Fi icon shows an x above it
01-04-2021 07:12
01-04-2021 07:12
I haven't had an answer to why this problem is occurring. It's just an expensive manual scale at the moment! Cheers for letting me know I'm not alone though.
01-05-2021 04:09
01-05-2021 04:09
I had the same issue this morning, and I've managed to figure it out. I had previously blocked the MAC address of the scales from my router, as I didn't know what that MAC was.
I've since unblocked it and its now connecting, so it might be worth double checking your wifi settings at the router.
01-05-2021 11:41
01-05-2021 11:41
same here. we moved and switched too rogers. it only detects bell networks.... how can i fix this
01-05-2021 11:55
01-05-2021 11:55
Sorry what did you say. Are you saying you've switched routers? What router do you have now? And what do you mean by bell networks?
01-05-2021 14:10 - edited 01-05-2021 14:11
I have all these requirements and it still is giving me an "Wifi ERR" whilest going through the setup configuration.
I have run into this problem since we switched internet providers.
01-05-2021 15:07
01-05-2021 15:07
We moved 4 hrs away so we had to switch providers (Rogers internet), when i go to reconnect it, the scale only detect networs from Bell.
01-05-2021 20:31
01-05-2021 20:31
Valerie P88,
Sorry to step in here but your internet provider has no relation to connecting to the Aria scale. The scale is only trying to connect to your personal router, which then communicates with your provider.
1. When you moved did you take and set up your original wifi router in your new home Y/N?
2. The 802.11 b/g/n 2.4GHz standard is pretty much ubiquitous on any wifi router so even if it is 5GHz capable it should also be capable of transmitting on 2.4GHz - however, it might be that the 2.4GHz transmitter is turned off, for example that is possible on many Asus dual band routers.
The only possible problem I can see is if you are in an apartment on shared wifi that you cannot control. Otherwise, it is time to get out your manual for your wifi router and do some reading on how to set it up.
01-06-2021 03:34
01-06-2021 03:34
Thanks for the reply,
When moved the a new house, we had to get a new router ( they're provided by our service providers) so it is a different one. We have Ignite WiFi Gateway Arris XB6 Modemfrom Rogers.
It has both 2.4GHz and 5GHz capable. I've checked ans both are turned on.
Most of our neighbors use rogers as well and I cant even detect their networks with the scale either.
01-06-2021 06:07
01-06-2021 06:07
Thanks for the reply. I haven't blocked any mac addresses. I'll take another look anyway.
01-06-2021 06:09
01-06-2021 06:09
That's the same issue I have. Same provider but different router. The scale didn't even see the neighbours Internet let alone mine.
01-06-2021 10:34
01-06-2021 10:34
Rogers might be blocking the scale somehow. Anyone know how to check
01-06-2021 12:43
01-06-2021 12:43
For what its worth my Aria 2 connects to my Asus RT-AC68U router no problem.
I assume you are doing the Wifi Setup procedure through the phone app?
02-03-2021 09:33
02-03-2021 09:33
12-24-2021 09:40
12-24-2021 09:40
My scale will no longer find any network. Seems to be the going consensus here.
12-25-2021 15:01
12-25-2021 15:01
I installed a new router with 3 wireless access points and made separate networks for 2.4 and 5ghz bands. Now when trying to reconnect my scale it doesn’t show my network in the list, even though I am literally right next to one of the access points.
I don’t have ant MAC blocking set up so there’s no reason it shouldn’t see it… it sometimes shows my neighbors SSID but never mine.
I tried manually entering the SSID and password and that doesn’t work either… but I did notice that the display changes from “SETUP ACTIVE’” to “NETWORKS DETECTED”.
Somewhat different results on iOS compared to Android, but in the end still not connected 😞
