07-02-2018
12:11
08:45
07-02-2018
12:11
08:45
So having difficulties connecting my new Aria 2 to Wifi.
It sees the network, accepts the password, tick apears then sync process then says can't connect
I have tried the following:-
What is my next step? Is this a firmware issue or an issue with the synchronisation servers?
Yours hopefully
P.s also tried taking batteries out for ten min, router is 8 feet in direct line of sight to router, there are other wireless devices on network which are working fine.
Geoff
12-13-2020 06:42
12-13-2020 06:42
02-02-2021 17:53
02-02-2021 17:53
@JuanJoFitbit wrote:@KarynaH Welcome to our Fitbit Community! I'm sorry to hear that your Aria 2 is not connecting to your network either. I would like to follow up on this issue and would like you to try the following troubleshooting steps: Restart your router and after this, set up your scale from scratch.
On an aside note, I would like to know if you made changes to your network (WiFi password, router or router settings).
@JSSC I'm sorry about the experience you had with your Aria 2. I appreciate your feedback and comments since this helps us to keep improving.
So,... I did actually have this problem and I have actually fixed it.
In my router setup, I disabled 20/40 MHz coexistence.
I also set the maximum WiFi mode to the 400 Mbps setting, but I'm not sure this was necessary.
I went from intermittent to no connection for days to a solid connection every time I weighed.
Hope this helps.
02-04-2021 12:55
02-04-2021 12:55
02-06-2021 13:21
02-06-2021 13:21
I am a long time fitbit user. very happy with the fitness tracker and now own my fourth device and my second scale (aria and after it broke, aria 2).
The aria 2 worked fine for years. just one day out of the blue it doesn't sync anymore. No firmware update on the aria 2 nor on my wifi / router equipment
I have unifi products for wifi/ router and have made all kinds adjustments, including a seperate SSID with 2.4b/g and low beacon speeds of 1mbit. This stupid device does not want to work with my wifi anymore. I see a successful connection, even getting an IP address via (so communication is fine!). After that nothing.
I ended up creating a hotspot on my iphone, which works. really terrible.
02-06-2021 19:58
02-06-2021 19:58
@Hansaplast26 wrote:I am a long time fitbit user. very happy with the fitness tracker and now own my fourth device and my second scale (aria and after it broke, aria 2).
Yeah, my problem with this seemed to start one day for no particular reason too.
From my reading about the 20/40 coexistence option, the router drops the WiFi speed/changes modes when the network gets more congested. From looking at a scanner, it does look like that is what happened.
02-07-2021 08:36
02-07-2021 08:36
I love that you prayed to various gods and minor deities - those gods can be real jerks if we don't pray to them, and the nymphs especially like to screw around with our scales.
02-09-2021 03:27
02-09-2021 03:27
Same as you 100%
02-09-2021 06:40
02-09-2021 06:40
Have same issue and tried all remedies suggested but still no connection.
Any other solution??
02-09-2021 07:41
02-09-2021 07:41
02-09-2021 14:54
02-09-2021 14:54
02-09-2021 17:55
02-09-2021 17:55
02-09-2021 20:31
02-09-2021 20:31
Personally, I'm confused as to why this question's "Best Answer" didn't actually resolve the problem.
This page has an "Answered" checkbox checked and 5 pages of replies that suggest it was not.
I actually have a positive, repeatable result. My scale now works perfectly.
Has anyone else been able to try disabling 20/40 coexistence on their WIFI router?
I'd really like to know if anyone else can get their scale to work the same way mine currently does.
It would be nice to be able to give Fitbit a push in the right direction, assuming this is in fact that.
02-10-2021 08:13
02-10-2021 08:13
02-15-2021 05:17
02-15-2021 05:17
Hi everyone. I totally understand how you feel about this since your Aria 2 scales won't connect with your WiFi networks. Please let me know if you receive any error message. Also, let me know if you have made changes to your network, such as router, WiFi settings or WiFi password.
In the meantime, try taking out the batteries for 15 seconds and put them back in. After this, try setting up your scales from scratch as instructed in this help page.
Looking forward to your response.
05-18-2021 04:02
05-18-2021 04:02
None of this worked
05-18-2021 06:21
05-18-2021 06:21
Hello @JuanJoFitbit ,This is a repeat of a prior post, but since
I HAVE A FUNCTIONING ARIA SCALE
...that was not communicating and as now been communicating, flawlessly, for months, I think it bears repeating:
"Personally, I'm confused as to why this question's "Best Answer" didn't actually resolve the problem.
It would be nice to be able to give Fitbit a push in the right direction, assuming this is in fact that."
This may not help you, but on the Netgear Nighthawk, the option is called 20/40 mhz coexistence and it appears to negotiate the bandwidth in a way that the Aria is incapable of doing.
Disabling this feature, allowed the Aria to connect. Enabling it did not immediately result in the Aria disconnecting, but it invariably failed a few days/weeks later with this option on.
Currently I have it disabled and as I said before, my Aria 2 has functioned flawlessly for months.
*** I really like my Aria 2 and I want it to succeed and continue to be available.
Regards,
05-18-2021 11:36
05-18-2021 11:36
I changed completely kind of battery (apparently my rechargeable battery where fkd up) since then is working again with no problem.
08-09-2021 16:40
08-09-2021 16:40
I just could not get the wifi to work again. Took an entire evening to set it up originally and now it just stopped working again. Spent 3 hours unsuccessfully to reconfigure it. A frustrated heel has now ensured my Aria 2 is going out in tomorrow's trash... Single worst product experience in my life. I've worked with IoT devices that are less complex & less error prone than this garbage.
Oh and Fitbit Support is as much of a joke as their products. I couldn't get anyone to help with this particular issue. Best I got was "we'll email you... sometime".
08-09-2021 16:42
08-09-2021 16:42
Same here. I gave up trying to get mine on wifi.
08-09-2021 23:48
08-09-2021 23:48
