07-02-2018 12:11 - last edited on 09-04-2019 08:45 by MatthewFitbit
So having difficulties connecting my new Aria 2 to Wifi.
It sees the network, accepts the password, tick apears then sync process then says can't connect
I have tried the following:-
What is my next step? Is this a firmware issue or an issue with the synchronisation servers?
Yours hopefully
P.s also tried taking batteries out for ten min, router is 8 feet in direct line of sight to router, there are other wireless devices on network which are working fine.
Geoff
08-12-2021 19:22
08-12-2021 19:22
@UCEngineerGirl wrote:Same here. I gave up trying to get mine on wifi.
Mine continues to work.
Aria evidently doesn't deal well with 40 mHz bandwidth.
On Netgear routers, disable 20/40 mHz co-existence.
On Linksys limit bandwidth to 20 mHz.
08-19-2021 19:36
08-19-2021 19:36
On ASUS, simply change the chanenl from 12 to 11...it works
08-31-2021 17:10
08-31-2021 17:10
We just moved and every time I step on my Aria 2, it does it’s thing and ends with a message saying “no Wi-Fi”. Can you help?
11-22-2021 07:11
11-22-2021 07:11
I just moved house. The Aria 2 worked pretty well previously and was connected to my home Wifi. Now I can't get it to connect. I've changed the batteries, pressed the button in the back. It doesn't seem go in to network search mode. I end up in a frustrating loop.
It timed out and let me manually enter the wifi name but even right next to the wifi it doesn't connect.
I can weigh myself but it doesn't connect to the wifi to register the weight and % body fat.
11-22-2021 07:28
11-22-2021 07:28
Mine still doesn’t work. I received no support from Fitbit. I’m done with it and will never buy another.
11-22-2021 13:05
11-22-2021 13:05
What brand?
I've had mine a while. 08 2020.
Nov 21 after a phantom unit change, no longer pairs.
05-11-2022 09:28
05-11-2022 09:28
Follow up, after I replaced my router,
Aria 2 did work with the settings I gave earlier for the Netgear Nighthawk.
The Aria 2 connected up with no issues or settings needing to be changed on the Eero equipment that replaced the Nighthawk.
06-12-2022 22:09
06-12-2022 22:09
I had the same issue with Aria 2 and I finally resolved it. I had various problems while connecting to WiFi, sometimes my Router won't show up in the pairing process, sometimes it showed, but failed to connect.
My router has a feature called "Band steering", which connects the devices automatically between 2.4GHZ and 5 GHZ. There was an option to add devices to these lists manually, so I checked my Aria MAC address in the battery compartment and put it to the 2.4GHZ list and it finally started working.
06-13-2022 11:53
06-13-2022 11:53
07-04-2022 06:26
07-04-2022 06:26
One thing I want to add. When you set up your Aria 2 - and it asks for your WiFi password - do NOT copy/paste it. You must MANUALLY enter the password. I made this discovery after several failed attempts to enter the WiFi password with a copy/paste. When I physically typed in the same password I tried to copy/paste, log on was successful.
I hope someone will find this useful at some point.
06-25-2023 07:49
06-25-2023 07:49
I have owned an Aria 2 for a long time now (years maybe?). I recently changed WiFi setups and lost connection to the scale from my iOS app. Following the usual process through the app seemed to fail constantly but here's how I got it to work finally.
This may not work for everyone, but I thought I would describe what it took for me to get my scale to get connected again.
Good luck.
