Aria 2 won't connect to my WiFi Network
My Aria 2 will not pick up my WiFi network (It picks up everyone else in the neighborhood though!) I have reset the scales and also tried unplugging the network. i just wont pick it up. I has previously worked. Please help its doing my head in !!.
2 REPLIES 2
Networking Requirements
Aria 2 connects directly to your home’s Wi-Fi network and supports the following
network configurations:
• Wireless 802.11b/g/n, 2.4 GHz standard
• WEP / WPA / WPA2 personal security
• Automatic (DHCP) IP setup (static IP configuration not supported)
Aria 2 requires an 802.11b/g/n-compatible network to connect and sync your scale
data to your Fitbit account.
Hi @Woolbag, welcome to our Fitbit Community! I'd like to follow up and help you with your Aria 2 since it's not connecting with your network.
Please let me know if your router complies with the settings that @SunsetRunner listed above. Also, make sure that you are following the setup process as advised in this help article.
Looking forward to your response.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
