08-08-2020
12:30
05:22
JuanJoFitbit
08-08-2020
12:30
05:22
JuanJoFitbit
My scales link up to my app as normal and the internet as normal but after a weighing it says no connection and gives random profiles. why is this. First time i had this issue.
Did change internet supplier to virgin media though.
08-10-2020 05:54
08-10-2020 05:54
After changing your Internet provider, did you use the app Aria 2 "WiFi Setup" to change the WiFi settings to your new router?
08-10-2020
13:49
05:17
JuanJoFitbit
08-10-2020
13:49
05:17
JuanJoFitbit
Yes I did any this did not work so I followed the trouble shoot of removing it from my account and pushing the button on the back then trying it this way and the same results.
connects to WiFi fine > stand in the scales to get weighed > shows wrong profile image and then says no WiFi connection symbol under the imagine then it shows the connection lost message.
Still the same problem
Moderator edit: merged reply
08-31-2020 05:21
08-31-2020 05:21
Hi @MattyLeeT18, it's great to see you in our Fitbit Community. Since your Aria 2 is still unable to connect with your network, please try resetting your router. After this, set up your scale from scratch as advised in this help article and see if the issue gets fixed.
Thank you for your help @USAF-Larry.
I'll be around if any question arises.
09-06-2020 22:35
09-06-2020 22:35
Tried this and still not worked
09-08-2020 06:24
09-08-2020 06:24
Hi @MattyLeeT18, thank you for getting back and trying the recommended troubleshooting steps. Since the issue persists, let me forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions.
