10-12-2018
10:12
08:45
10-12-2018
10:12
08:45
Hi I recently moved and was re setting up my aria 2. Whenever trying to set up it says the scale can not be found. And when trying to remove the batteries and doing it that way the screen will only say “www.fitbit.com/setup” but nothing is working. It’ll also say it’s connected to WiFi but then when I go in it says no networks can be found. And it will not sync. Help please!
02-24-2019 11:06
02-24-2019 11:06
02-25-2019 07:03
02-25-2019 07:03
@listentothehoff Thank you for participating in our Fitbit Community! I'm sorry to hear about the setup issues you experienced with your Aria 2. However, I'm so glad to hear that you managed to get it connected after installing a new router. Thank you for posting the update here.
Thank you so much for your great contribution @Rocxylemmon!
Have you guys heard about our Discussions board? In this board you'll be able to meet people, start your own topics and share your experiences.
Hope to see you both in our Fitbit Community more often!
05-11-2019 16:20
05-11-2019 16:20
Same thing happening here. I know my way around problem solving these issues but this is leaving me a little frustrated. Probably going to return scale and go with the Garmin. Was looking forward to the integration with my charge 3
05-13-2019 04:16
05-13-2019 04:16
@Jrd23 Welcome aboard to our Fitbit Community! I'm sorry about the connection issues that you are experiencing with your Aria 2. I totally understand your frustration.
I'd like to help you and turn the bad experience you've had with your scale into a good experience. Please let me know if you get any error message while trying to set up your Aria 2. Also, make sure that you are following the setup process as described in this help article.
Keep me posted!
05-13-2019 04:44
05-13-2019 04:44
05-14-2019 04:19
05-14-2019 04:19
@Jrd23 I'm sorry that you returned your Aria 2. I understand how you feel about this and appreciate your feedback since this helps us to keep improving.
Don't hesitate to get back if you have any questions!
09-11-2019 05:46
09-11-2019 05:46
there is nothing more annoying than to buy a brand new product, bring it home only to find it doesn't work - and some different "work-around" found from an internet search is needed to solve it. what else is wrong with my device I wonder?
09-11-2019 20:07
09-11-2019 20:07
Emotional roller coaster, I have tried all of these suggestions, but to no avail. Can't believe the amount of money and time wasted on this. Was hoping it would help me on my weight loss journey.
Get it to the point where I put in the 4 digit code and then it just spins and spins.... Phone says it's taking longer than usual and my Aria 2 says go to fitbit.com/setup, where it naturally tells me to download the app I started at in the first place.
09-19-2019 11:58
09-19-2019 11:58
I've had a lot of the same connectivity issues. This is connected device 101. They have to get this fixed soon or they stand to lose a lot of customers. Having a connected device is useless if it won't connect.
01-08-2020 09:45
01-08-2020 09:45
What worked for me was NOT going through the www.fitbit.com/setup You're not looking for "Aria 2" on your network connections at all. Instead, download the Fitbit app and add a new device. It will have you connect to Bluetooth first, then to wireless. It needs to connect to YOUR wireless network. This is what worked for me. Hope this helps!
01-15-2020 23:02
01-15-2020 23:02
Exactly the same issue for me, the response from Fitbit was like they didn't even read my message or look at the image that I attached lol
04-13-2021 08:21
04-13-2021 08:21
I had exactly the same issues. This worked. Very buggy software/hardware.....but works great when set up.
04-14-2021 04:05
04-14-2021 04:05
Hi guys I know how frustrating this was for you and I'm sorry about the issues that your Aria 2 scales experienced. Your feedback is greatly appreciated.
