03-26-2020
14:33
11:20
JuanJoFitbit
03-26-2020
14:33
11:20
JuanJoFitbit
Tried to weigh myself as I normally do and it initially read my weight as 399lb (after being 223 yesterday, I guess those shredded beef sandwiches are killers) which clearly wasn't accurate so I deleted the weigh-in from the app. I then re-weighed myself and got 140lb, which also was clearly wrong. I thought the scale must be malfunctioning/bugging out somehow so I popped a battery out for a second, reinserted it, and the scale briefly showed an exclamation point on the screen and then nothing.
Now it won't display or record weight at all. I've since taken the batteries out and I'll give it another try in the morning in case it needs some kind of prolonged reset or something as I've seen people post about doing for wifi connection problems. Has anyone had a similar issue?
Same symptoms this morning, put the batteries back in, only displays an exclamation point briefly and then nothing, even when I step on it.
03-28-2020 07:54
03-28-2020 07:54
Hello @vuvuzealot and a warm welcome. That exclamation point is an error code for a potential hardware failure. It sounds like you had your batteries out for 10 seconds before reinstalling them. It's time to contact Support.
Laurie | Maryland
04-20-2020 11:26
04-20-2020 11:26
Hi @vuvuzealot, due to the recent events, I apologize for the delayed response. However, I let me welcome you to our Fitbit Community.
Regarding the display and weight tracking issues that your Aria 2 experienced, I was able to get in touch with our Support team and was told that they assisted you via phone. I'm so glad to hear that a solution was provided.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Thank you for your help @LZeeW.
I'll be around if any question arises.
