07-19-2020
11:42
05:22
JuanJoFitbit
07-19-2020
11:42
05:22
JuanJoFitbit
My aria 2 scale aren't showing the right body fat%
In two days I went from 21.6% body fat to 17.5% body fat.
I know 21.6% should be the right % since I have gain weight in this corona time. I was in the 17% when corona started and didn't look like what I'm looking like today.
Nothing I do will Calibration the device.
Best Answer08-26-2020 05:22
08-26-2020 05:22
Hi @JorgM, I'd like to follow up and help you with your Aria 2 since it won't provide accurate body fat readings. By the way, thank you for troubleshooting this issue before contacting our forums.
In order to avoid providing the same information, let me know how you did the calibration. In the meantime, restart your scale by taking out the batteries for 15 seconds and put them back in. After this, weigh yourself 5 times in a row and see if it provides more accurate body fat readings.
Looking forward to your response.
Best Answer09-07-2020 01:59
09-07-2020 01:59
Hi Juan.
To calibrate my aria scale I had to do everything you wrote.
But stepping on the scale 5 times to calibrate wasn't enough.
Had to do it about 20 times before the scale became stable on the body fat %
Then I switched it over on lean mode and back to regular and did the calibration one more time to see if it became stable at the same % as the first time. And both times the same % was shown.
And the % was almost the same as the scale showed before the calibration problems.
So I'm happy now and satisfied.
Best Answer09-12-2020 06:01
09-12-2020 06:01
Hi @JorgM, thank you for getting back. I'm so glad to hear that you managed to get the issue resolved and your Aria 2 is providing accurate body fat readings now. Thank you for posting the update here and sharing the steps you took.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! 😀
