05-19-2023 17:43 - edited 11-09-2023 19:47
Yesterday, my scales didn’t recognize me and said guest during the weigh in. In went into the app - recent weigh ins, and changed it to me. Today, the scales didn’t recognize me again. I went into recent weigh ins, but this time, there was no guest weight registered. So, I tried three more times and got nothing.
I then came to the Community to search for help. So far, I’ve tried removing the batteries and stepping on the scales 5 times (6 times, just in case) to recalibrate. Nothing. Tried that again. Nothing.
I’ve removed the scales from my app and readded them (twice); logged out of the app and back in (6 times); done a hard reset of my device (3 times), and then tried adding the scales again (twice). Tried removing the batteries again, and then stepping on 5 times again. I then got on to my Fitbit account via the web browser, hit the settings cog, gone into my Aria 2 to look for recent weigh ins and possibly change it to me there. However, I can’t find any data about weigh ins on the website.
It’s been 2.5 hours now, and I’m ready to throw the scales out the window.
Can anyone advise, please?
_________________________________________________
Update #?? (I've lost track of what number update this is)
Posted my query back in May. Six months later and still NO MEANINGFUL UPDATE from Fitbit.
Moderator Edit: Updated post.
02-28-2024 04:22
02-28-2024 04:22
Hi,
So I had the same problem, i managed to get the scales to recognise myself 78kg but not my partner 60kg "GUEST". i got her to do a weigh-in, i did one within the same timeframe and set the weigh-in (my one) as her login. it seems to have tricked the aria 2 into thinking that was her. i got her to do another weigh in at her current weight, and just deleted the fake original weigh-in and now it works for her.
It's super stupid and fitbit really needs to work out their **ahem**ty app. Hope this helps!
J
03-09-2024 11:18
03-09-2024 11:18
A year later and still no fix? Guest weigh ins go into cyberspace and can’t be seen in recent weigh ins or assigned to users???! Update please.
03-14-2024 05:40
03-14-2024 05:40
My cat always sit over the little display and I cant see his weight and I cant find the guess weight no where on the app or on the fitbit website anymore. Its anoying.
Best Answer03-17-2024 13:50
03-17-2024 13:50
This was "escalated" nearly a year ago. Terrible customer service. That's google. They don't care.
03-17-2024 14:09
03-17-2024 14:09
@proteus007 wrote:Fitbit is not going to fix it. The product team is aware of the issue and has chosen to not fix it according to their reply to me.
Did they definitively tell you it will never be fixed, proteus007? Apologies if you've reported it here before, can't see it.
If support knows that, they should say so here, and end this thread.
Best Answer03-17-2024 15:31
03-17-2024 15:31
If they were going to fix it they would have. Even if they say they will, actions speak louder than words.
Speak with your wallet. Support brands that support their customers.
03-17-2024 15:43
03-17-2024 15:43
Withings is a Fitbit partner. So you can get a Withings scale and it will sync with Fitbit.
Wish this issue had more attention, Google purchasing Fitbit then not supporting a specific aspect anymore.
03-17-2024 15:58
03-17-2024 15:58
When you buy a company you usually buy the staff too. So if anything it's just the original Fitbit staff still being incompetent or stretched with other higher priority issues.
In saying that... I posted a workaround recently, if the Fitbit team was competent they'd pin my message so other users would find a way that's currently better than nothing.
03-23-2024 10:22
03-23-2024 10:22
This is still happening 😞
Cant beleive FITBIT is now working on a solution 😞
03-23-2024 10:23
03-23-2024 10:23
well, tried it, I did not do the trick for me 😞
Best Answer03-23-2024 10:31
03-23-2024 10:31
Don't hold your breath. They don't care.
03-23-2024 10:57
03-23-2024 10:57
I just created a new user and that did the trick ? yeap, you lose the tracking, but at least you can use it again : /
Best Answer03-26-2024 05:51
03-26-2024 05:51
It looks like I somehow was logged a weigh in of 50 lbs (???) a few weeks ago, and now all of my weigh ins our GUEST, even after deleting the erroneous 50 lb weigh in. A few years ago, this would have been easy enough to fix, but it would appear that GUEST weigh ins just disappear into the void now and cannot be accessed in any way?! And it has been this way for over ten months????????
I expected things to go downhill once Google bought everything. I didn't expect my scale to become one more of their many abandoned products. Absolutely ridiculous.
03-26-2024 07:25
03-26-2024 07:25
Fitbit has left the building...
