05-19-2023 17:43 - edited 11-09-2023 19:47
Yesterday, my scales didn’t recognize me and said guest during the weigh in. In went into the app - recent weigh ins, and changed it to me. Today, the scales didn’t recognize me again. I went into recent weigh ins, but this time, there was no guest weight registered. So, I tried three more times and got nothing.
I then came to the Community to search for help. So far, I’ve tried removing the batteries and stepping on the scales 5 times (6 times, just in case) to recalibrate. Nothing. Tried that again. Nothing.
I’ve removed the scales from my app and readded them (twice); logged out of the app and back in (6 times); done a hard reset of my device (3 times), and then tried adding the scales again (twice). Tried removing the batteries again, and then stepping on 5 times again. I then got on to my Fitbit account via the web browser, hit the settings cog, gone into my Aria 2 to look for recent weigh ins and possibly change it to me there. However, I can’t find any data about weigh ins on the website.
It’s been 2.5 hours now, and I’m ready to throw the scales out the window.
Can anyone advise, please?
_________________________________________________
Update #?? (I've lost track of what number update this is)
Posted my query back in May. Six months later and still NO MEANINGFUL UPDATE from Fitbit.
Moderator Edit: Updated post.
06-18-2023 06:08
06-18-2023 06:08
I really appreciate everyone keeping up the pressure on Fitbit Support to fix this. I feel like I am losing hope and I'm starting to consider a new scale...are there any suggestions for a good one?
06-18-2023 06:39
06-18-2023 06:39
I'm afraid Fitbit support doesn't even KNOW about it, because this was the answer to my support request I just received yesterday:
"Thank you for contacting us since you cannot see the other user's weight on your mobile. We'll be happy to continue assisting you.
We recommend the following troubleshooting steps:
Hope it helps!
If you have any other questions, please visit help.fitbit.com
Sincerely,
Grethel and the Fitbit Team"
06-18-2023 11:26
06-18-2023 11:26
I’m sorry they’re so useless. It’s happening for me across 2 iPads and multiple phones. But sure, “turn it off and on again” is their fix. 🙄 It was undependability like this that stopped me using their trackers years ago. The scale has been solid up until now. And again, it works fine for me… but not anybody else in the house. So frustrating.
06-18-2023 11:49
06-18-2023 11:49
I tried this solution, weighing myself 5 times with paper on the scale, and 5 times without, and only the weigh-ins with paper were logged in the app. Nothing to reassign, just not logged. If we buy new non-Fitbit scales that currently sync with the Fitbit app, I am wondering if the interface will continue to work now that Google has bought Fitbit.
06-18-2023 11:51
06-18-2023 11:51
It's obvious that, because they've discontinued the product, a fix is incredibly low priority for the engineers. They'd much prefer we give up and buy a replacement from the newer range rather than support something that (at least in my case) is less than 2 years old. Isn't that right @JuanFitbit ?
Plus, the first line support is only ever likely to say "turn it off and on again" "restart the app" etc.
06-18-2023 12:49
06-18-2023 12:49
Okay, so, MAYBE the bigger question now is: has anyone researched replacement scales? I’m immobilized because newer ones have so much extra I don’t want or need!
06-18-2023 14:10
06-18-2023 14:10
Google acquired Fitbit in January of 2021. Things have been going downhill for me ever since then.
06-18-2023 14:38
06-18-2023 14:38
Yeah. The same with Nest. Google gobbles them up and they become shells of what they could have been 😔
06-18-2023 21:19
06-18-2023 21:19
06-19-2023 03:06
06-19-2023 03:06
I have just purchased the Aria Air scales. Is this discontinued because I’ve literally just bought them. I am having issues adding a user atm. I invite them, go through the set up and it then says they need to be invited and we go round in circles.
If these scales are discontinued all return them as I only bought them last week
06-19-2023 09:11
06-19-2023 09:11
Same issue here. Everything was fine, then I had to replace my batteries. Once I did this, I am not a guest, with no body fat, and I cannot find the logs to attribute it to myself. It also says it's syncing correctly.
06-19-2023 09:24
06-19-2023 09:24
Hello JuanFitbit and thank you for the reply.
Do you have any updates?
06-19-2023
10:36
11:27
JuanFitbit
06-19-2023
10:36
11:27
JuanFitbit
Hi, Here are some recommendations from Wirecutter. The Wyze Smart Scale X gets good reviews and syncs with the Fitbit app.
Moderator edit: link removed
06-20-2023 12:35 - edited 06-20-2023 12:38
Hi
Aria 2 is showing me as guest despite me having unpaired and paired many times today. Also it is not calculating fat percentage & BMI. Also it is not syncing the readings to the App even though it shows syncing successfully on the scale and is not showing weight on the App since 9th of June. This has become a recurring theme with Fitbit products.
06-20-2023 14:53
06-20-2023 14:53
My Android app is doing the exact same. It only shows weigh ins that the scales recognise and me. Any time my scales think I'm a guest I have no visibility of these weigh in to reassign this. The timescale sounds pretty similar too. On the PC page I can't even see any weigh ins on the Aria page at all, it only tells me I can still assign another 6 users. Seems to be just one more issue of many since Google took over!
06-20-2023 19:06
06-20-2023 19:06
Same here. I’ve tried all the documented solutions to get it to register me but it keeps thinking I’m a guest. And now won’t show guest weights. 😐
06-21-2023 01:21
06-21-2023 01:21
I also have an open ticket - nothing seems to be being done about it
06-21-2023 05:12
06-21-2023 05:12
@Pallava My Aria 2 somehow decides I'm a guest on my own scale about every 1-2 weeks. Guest weights aren't showing up on the app, so we can't reassign them to our own accounts. This workaround worked for me every time since this started:
Your scale needs to recognize you to calculate %BF and BMI.
Laurie | Maryland
06-21-2023 08:03
06-21-2023 08:03
I also have an open ticket. They say the developers are working on it .... We shall see. Google.
06-21-2023 13:31
06-21-2023 13:31
I discovered that the web dashboard DOES show my weights. It's under the "see more" button under your weight. But I can only see mine, and no longer anybody else in my household.
