08-30-2018
17:45
07:17
JuanJoFitbit
08-30-2018
17:45
07:17
JuanJoFitbit
My aria2 scale will show my weight but when it gets to the body fat percentage, it just says "---%". I know it does that when you wear socks but I'm barefoot like I'm supposed to be. It used to work fine but now it does that EVERY time. Any suggestions?? I've tried unpairing and re-pairing.
Moderator edit: subject format
09-27-2018 06:21
09-27-2018 06:21
@ElementalWisp Thank you for your feedback! I also appreciate your time and patience. They will contact you soon.
10-07-2018 16:21
10-07-2018 16:21
My scale is the same, only about 4 months old and body fat % doesn’t work. I have tried all the “fixes” mentioned, but nothing is working.
10-08-2018 06:35
10-08-2018 06:35
@Teranio925 It's great to see new faces in the Fitbit forums! Thank you by the way for troubleshooting this issue before contacting the forums. Since issue persists, I will escalate your case to our Customer Support department and they'll be happy to follow up. Please keep an eye on your email account.
I'll be around if you have any doubts!
10-14-2018 05:31
10-14-2018 05:31
I’m also having the same issue and my Aria 2 is also about 4 months old. One day, no more bidy fat readings. Just two dashes. Has there been a reason and fit identified yet? It seems that this issue has been out there for a while, based on the other messages here.
10-15-2018 05:06
10-15-2018 05:06
10-15-2018 06:04
10-15-2018 06:04
Thanks! I’ll reach out to them today. I hope your new one is working well.
10-16-2018 08:43
10-16-2018 08:43
@JerseyJeff97 Thank you for joining us in this thread and our Fitbit Community! I would like to follow up on your case and since you mentioned that you were going to contact our Support team, I'd like to know if they provided a solution.
@jabudia I'm glad to hear that our Support team sent you a replacement unit. Thank you for posting the update here. I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
See you guys around!
10-16-2018 15:05
10-16-2018 15:05
How old was your Aria 2? As Support said mine was out of warranty
10-16-2018
16:04
07:21
JuanJoFitbit
10-16-2018
16:04
07:21
JuanJoFitbit
Thanks, yes they are addressing my issue.
My Aria 2 was less than 2 months old.
Moderator edit: format
10-16-2018 16:56
10-16-2018 16:56
Please clear up the apparent discrepancy between my issue with my Aria 2 and @jabudia and FitBit's resolution I was told to buy a new Aria 3.
10-17-2018 01:29
10-17-2018 01:29
It does work, maybe not ideal, but it requires minimal fiscal effort. It'l be better if you had to carry your aria over a 1k steps up and down. I really need to get some exercise.
10-17-2018 14:25
10-17-2018 14:25
Mine was about 4 months old.
10-18-2018 07:13
10-18-2018 07:13
@mfr81 I'm sorry to hear that your Aria scale us out of warranty. I totally understand how you feel about this and I appreciate your feedback and comments.
@JerseyJeff97 I'm so glad to hear that our Support team is already handling the issue. Thank you for posting the update here.
@jabudia Thank you for your feedback.
@KravenVD Thank you for joining our Fitbit Community! In order to avoid any misunderstanding on my end, please let me know if your Aria is not tracking your body fat percentage either. If this is correct, please provide more details of the issue and let me know if you have tried some troubleshooting steps.
See you all later!
10-18-2018 07:54
10-18-2018 07:54
It works fine after I meassured myself a couple of times in a row.
10-20-2018 04:09
10-20-2018 04:09
@KravenVD I'm so glad to hear that your Aria scale started working properly after you re-calibrated it. Thank you for posting the update here.
Hope to see you in our Fitbit Community more often!
03-13-2019 15:12
03-13-2019 15:12
Has a fix for this been discovered? Mine is not showing body straight from the box. I tried the things mentioned here.
03-14-2019 12:10
03-14-2019 12:10
@Sld82 Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your Aria 2 not providing body fat readings after trying the recommended troubleshooting steps.
Due to this, I will forward your case to our Support team and they'll be happy to follow up and assist you accordingly. Please keep an eye on your email account.
I'll be around if you have any questions!
03-14-2019 15:06
03-14-2019 15:06
I've heard nothing from Fitbit regarding the issue. I've tried the fixes recommended and they don't fix the problem. I just don't get why it randomly worked for me 3 times, but just doesn't work most of the time...come on fitbit, sort out my scale!!
03-15-2019
05:37
07:08
JuanJoFitbit
03-15-2019
05:37
07:08
JuanJoFitbit
When it does work I question the accuracy.
The highlighted is me switching from normal, to lean and back to normal, please don't tell me this is averaging or calibration. What exactly are u calibrating to? Resistance is defined so am interested in the need for calibrating. There seems to be some variability in the data which I suspect is averaging...but the measurement is absolute. My foot sweat (nice) and position varies yes....don't try and compensate for this....if I weigh my lean chicken....don't interfere trying to be clever.
The hubit scale I use has been consistent and I use them side by side when suspicious..my wife refuses to use the aria2....it's a third of the price and my only gripe is it's poor graphing feature...I'm on my weigh there now...pun intended!
Moderator edit: merged replies
03-19-2019 07:16
03-19-2019 07:16
@Samrason @PaulGreatrex I'm sorry for the late response. However, I want to follow up and since you guys are experiencing issues with the body fat accuracy, I'll send your cases to our Customer Service department so they can further investigate and help you accordingly.
You'll receive an email from them soon.
Keep me posted if you have more questions!
