08-30-2018
17:45
07:17
JuanJoFitbit
08-30-2018
17:45
07:17
JuanJoFitbit
My aria2 scale will show my weight but when it gets to the body fat percentage, it just says "---%". I know it does that when you wear socks but I'm barefoot like I'm supposed to be. It used to work fine but now it does that EVERY time. Any suggestions?? I've tried unpairing and re-pairing.
Moderator edit: subject format
07-14-2021 20:20
07-14-2021 20:20
Hi,
I’m having this issue. Tried to weight 5 times in a row with no luck. Any suggestion?
07-26-2021 08:06
07-26-2021 08:06
If you are out of warranty, you are out of luck. Buy a new scale that's not Fitbit.
08-02-2021 17:37
08-02-2021 17:37
Same issue. I just tried removing the batteries for over 15 seconds, replacing them, and weighing myself five times in a row. All five times, the body fat came up as --%. This has been happening for several months now.
08-02-2021 23:47
08-02-2021 23:47
08-13-2021 15:17
08-13-2021 15:17
Are you just going to keep telling us that it's great to have us in the community or are you going to tell us how to solve the **ahem** problem??!!! Mine has done this since the day I got it. Any software updates that may have happened did nothing to fix the problem and I am quite frustrated! ANSWERS NOW!!
06-13-2022 14:10
06-13-2022 14:10
I am having the same problem. I have tried all of the suggestions and nothing has changed
10-25-2022 18:27
10-25-2022 18:27
I’m having the same issue. I just setup my scale again and weighed myself 5 times. Still doesn’t show body fat percentage.
11-07-2022 12:32
11-07-2022 12:32
I have had the same problem for over a year, however on very rare occasions I will get a body fat reading. I recently tried to fix the problem and stumbled across this group. I have done all of the suggested "fixes" including washing the surface of the scale but have had no success in getting it to work. Help!
11-07-2022 12:58
11-07-2022 12:58
If it's still in warranty then send it back and get a refund. Then buy a different scale (not Fitbit). I've had no problems with Eufy C1 smartscale. Aria2 just doesn't work.
11-07-2022 13:07
11-07-2022 13:07
I got so frustrated that I actually bought another scale that give way more information that the aria. Good to know other had/have this issue, thanks.
01-30-2023 07:55
01-30-2023 07:55
I’ve done all of the “fixes” numerous times, and they don’t work. My Aria has shown body fat ONCE, since I’ve had it. Very disappointed, and out $129.
01-30-2023 08:33
01-30-2023 08:33
I know your frustration and I also am out $130, however; mine actually worked (showed my bodyfat % a bunch of times) and then it just stopped. I recommend the Renpho scale, it was about $30 and measures all sorts of stuff, not just weight/bodyfat. Good luck!
01-30-2023 11:39
01-30-2023 11:39
The worry for me is this issue was first reported 5 years ago and here we are in 2023 and the issue has still not be fixed/resolved.
06-03-2023 11:32
06-03-2023 11:32
Just an update on this, mine suddenly started working a few days ago.... No idea why, or how long it'll last...
06-28-2023 10:39
06-28-2023 10:39
Hi Everyone.
In order to have the community better organized, I'll proceed to close this thread. If you want to share ideas, have any inquiries or need help about other concerns please visit the community.
