01-02-2020 15:06
01-02-2020 15:06
Trying to connect my new Aria 2 to my wifi. It finds a list of other wifi but does not find mine. When I manually type the details into the other, message says the network is "not available"
Very frustrated
01-04-2020 12:58
01-04-2020 12:58
Is your WiFi a compatible 2.4?
Is your phone or computer connected to the same network?
01-04-2020
16:10
06:11
JuanJoFitbit
01-04-2020
16:10
06:11
JuanJoFitbit
Yes to both. Computer and iPhone are connected to wifi. The wifi is
compatible with 2.4.
I came here hoping to get some help from Fitbit. How do I get help from Fitbit support? Or should I return this product?
Moderator edit: merged reply
01-20-2020 15:08
01-20-2020 15:08
If you are looking for help from fitbit support, tap on your photo in the top right. Then tap Contact Support.
If you want help from your fellow Fitbit users, your in the right place.
01-23-2020 11:00 - edited 01-23-2020 11:01
I had the same problem. Here is what worked for me:
What I found out was that if you re-enable 5GHz without first reserving the ip address, the scale would not detect the Wifi and will not sync.
Hope this helps.
09-08-2020 04:22
09-08-2020 04:22
Honestly, if I had known it was this difficult I would have bought a different scale. I will return it if I have to do all this.
09-08-2020 06:10
09-08-2020 06:10
Hi @Mika1984, thank you for participating in our Fitbit forums. I'm sorry to hear that your Aria 2 won't find your WiFi. I totally understand how you feel about this. I would like to follow up and would like to know if your Aria 2 displays any error message.
In the meantime, please make sure that you followed the setup process as advised in this help article. This article also contains a list of the router requirements that the Aria 2 needs to connect with a WiFi network.
Keep me posted on the outcome.
