09-12-2020 09:18
09-12-2020 09:18
on Monday I used my scale, everything was working fine. I put it under my cabinet as usual, and noticed the display didn't turn off. When I took it out again, the display was stuck at 0.0 lbs, and would not change when stood on. I have taken out the batteries, replaced the batteries, tried to do a reset and nothing is working. It would be lovely if someone had a result for me to try. I appreciate your time!
Best Answer09-14-2020 05:06
09-14-2020 05:06
Hi @LaanstraP, welcome to our Fitbit Community. I'm sorry to hear that your Aria Air got stuck at 0.0 lbs. By the way, thank you for troubleshooting this issue before contacting our forums.
Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
