01-10-2022
12:36
12:48
LizzyFitbit
01-10-2022
12:36
12:48
LizzyFitbit
Just purchased the aria air, but was wondering if I have multiple users are there weight just for them to see and not others thanks
Moderator Edit: Clarified subject and updated label
01-23-2022 09:42
01-23-2022 09:42
Hello @Sheze and welcome to the Community. Fitbit mostly solved the multi-user privacy issue with the Aria Air. When you weigh yourself, you need the Fitbit app open and in range. When you step on the scale, a dialog box opens on the app with your weight. Tap on Save to save it. The reason I wrote "mostly solved" is because of a user post. They said that two users had the app open and the weight displayed on both apps. I can't recreate this on my Aria Air because I am the only user. Privacy is definitely improved over the Aria 2, where all a user had to do is re-assign the weight to themself.
Laurie | Maryland
01-24-2022
13:36
10:56
01-24-2022
13:36
10:56
Welcome, @Sheze. It's nice to see a new face around. @LZeeW Thanks for your great help!
@Sheze I'm glad you got a new Aria Air and I understand your concern about your data. In addition to @LZeeW's post, let me share that you can choose if you want your data be visible for other people connected to this scale. To do that, please give a try to the following:
You can ask the rest of the users to do the same in case they want to hide or show their data. To learn more about your Fitbit profile and how to control the information you share with your friends, I'd recommend reviewing this help article.
01-24-2022 14:04
01-24-2022 14:04
Thank you I’ve still not set it up yet 🙈 but I will thanks for the advice
01-28-2022
16:27
10:56
01-28-2022
16:27
10:56
@Sheze It's good to see you around.
You're welcome! Thanks to you for taking the time to review the suggestions shared here. I hope you can enjoy the experience with your Aria Air and if you need help with the set up process, check this help article. You can always create a new thread if you have another question, I'm sure the Community will help you with that.
Have a good one.
