I've been having intermittent problems with my Aria Air not automatically syncing for awhile, I've had success with various workarounds ie, forced stop, restart, reboot, etc but since the "stealth" UI update none of these work, touching log weight opens a window with the weight entry being a required field that will not update, however.
I'm in the UK so my weight preference is stone. This seems to be the problem. If I change my preference to lbs in weight, ie weight >weight settings >units and change it to lbs ( I also changed the Aria Air scale to lbs ), it works flawlessly, every time. Reverting it to stone does not work.
Hopefully this will help other users until fitbit / Google update the app' to auto-sync and recognise stone and pound as a preference.
